Coax: RG-6 Quad or regular for UHF at 70 mi? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-08-2013, 05:57 PM - Thread Starter
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
When dealing with weak UHF signals from 70 miles, as well as strong local UHF/VHF signals, is RG6 Quad Shield recommended or is regular RG6 cable a better choice? And is Lowes/Home Depot/Walmart variety ok or is there a better brand to order? Using attic antenna and preamp. Thanks.
tylerSC is offline
post #2 of 5 Old 03-08-2013, 06:03 PM
ProjectSHO89's Avatar
Quoted: 211 Post(s)
Liked: 110
RG6 is a tiny bit less lossy than is QS, but you'd need precision test equipment to tell the difference.
The "name" brand stuff from the Borg stores is usually pretty good.
ProjectSHO89 is offline
post #3 of 5 Old 03-08-2013, 07:19 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Don't waste your money on Quad. The main difference is in the shielding construction. The attenuation is the same whether it's standard, Tri, or Quad.
T
CIAO!
Ed N.
egnlsn is offline
post #4 of 5 Old 03-09-2013, 06:03 AM
Super Moderator
DrDon's Avatar
Quoted: 876 Post(s)
Liked: 1734
Please keep topic titles specific. See my edit.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #5 of 5 Old 03-26-2013, 12:22 PM - Thread Starter
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
For those interested, Home Depot now has very good clearance prices on GE branded coax cable, splitters, connectors, and indoor antennas. The RG6 quad shield is $9.99 for 25ft, and the regular RG6 even cheaper. Appears to be good quality. They are preparing to switch brands.
tylerSC is offline
Reply HDTV Technical
