Test patterns on Comcast cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-10-2013, 02:22 PM - Thread Starter
bearr48's Avatar
Is there any way to see test patterns such as pluge patterns or color bars on Comcast cable? I couldn't find anything in the forums, and the kid I spoke with at Comcast was clueless? Thanks. Jack
bearr48 is offline
post #2 of 5 Old 03-10-2013, 04:40 PM
sitlet's Avatar
I don't know why they would broadcast those. And if they did, they would be compressed as hell.
sitlet is offline
post #3 of 5 Old 03-11-2013, 03:24 PM
Milt Frankel9's Avatar
i am in walnut creek ca. with comcast. there is a channel with color bars on the highist channel.
milt
Milt Frankel9 is offline
post #4 of 5 Old 03-11-2013, 07:28 PM
olyteddy's Avatar
Quoted: 531 Post(s)
Liked: 931
Since there is a lot of repetitive data in a test pattern I should think they would compress and restore fairly well. Consider color bars for example. The entire pattern is comprised of around a dozen pieces. Why not compress it?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 5 Old 03-14-2013, 04:38 AM
RCbridge's Avatar
Quoted: 16 Post(s)
What are you trying to do?
RCbridge is offline
Reply HDTV Technical
