Stacked XG91s Amplifier Options... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-10-2013, 03:58 PM - Thread Starter
gaz-in's Avatar
Quoted: 13 Post(s)
Hi All,
First here is my tvfool report:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda97e9d373ae
I have two XG91s and plan to stack them. I have narrowed it down to two options and would appreciate your input.
Option 1: Two XG91s feeding a combiner and then on to a Kitztech KT--200. Link to KT-200 amp
http://www.kitztech.com/
Option 2: Two XG91s each individually feeding it's own Winegard LNA-100 and then on to the combiner. Here is the link to the LNA-100:
http://www.solidsignal.com/pview.asp?p=lna-100&d=winegard-lna100-boost-20db-digital-tv-antenna-amplifier-with-clear-circuit-technology-(lna-100).
I would appreciate hearing your thoughts...
gaz-in is offline
post #2 of 2 Old 03-10-2013, 07:11 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
The Kitztech 200 is a reportedly a good low noise preamp. But the Winegard LNA-100 is a new product that does look promising. And apparently a USB powered option. Looks similar to new Mohu Jolt amp, but with slightly more power. But even if you use Winegard amp, I think only one amp configuration into antenna combiner is all that should be used, same as your idea for Kitztech. Using 2 amps may actually degrade signal or overload.
tylerSC is offline
Reply HDTV Technical
