Curved Lines in Gray Solid Tones - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-12-2013, 09:59 AM - Thread Starter
mrhagerty's Avatar
I've looked at some threads here and those that deal with banding problems all have to do with backlighting issues and screen uniformity.
My problem is a little different.
I have an older model Sharp AQUOS HDTV and on analog movies where a large part of the screen is showing gray clouds or sky, or fog scenes, I get noticable curved lines that break the image into curvey horizontal sections down the picture. Not the same as dis-uniformity of backlighting as described elsewhere.
Anyone have an explanation for this phenomenon, or can you point me to a prior post?
Mike
mrhagerty is offline
post #2 of 2 Old 03-13-2013, 06:36 PM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1731
Sounds like typical MPEG artifacts. They're more visible on an HDTV set displaying SD images.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Reply HDTV Technical
