HDMI Matrix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-20-2013, 12:43 PM - Thread Starter
jbh5000's Avatar
I have actually been wondering about a potential setup.
In order to keep from spending $10k+ on a huge matrix could you do:
8 different 2x1 matrixes and have each one feed into a 8x8 matrix....then you could effectively have a 16x8 matrix at a much lower cost.
But you would have to strategically connect them because you couldn't use 2 sources from one 2x1 matrix simultaneously.
Then use CQC to automatically select the proper inputs etc.....
Does anyone have any experience with this? Would this work?
jbh5000 is offline
post #2 of 2 Old 03-29-2013, 05:19 PM
Doctego's Avatar
Liked: 42
If you post this in the HDMI forum, I'm sure that Joe or Andy could answer this for you.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
Reply HDTV Technical
