Help please with HDTV tuner / Channel Master 7001 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-21-2013, 09:04 PM - Thread Starter
Harrypt's Avatar
Hope someone can help me, I'm now on my third HDTV tuner!
We stream most of our TV so we just have basic cable with no set top box but I have one of the early Panasonic plasmas stricken with a weak or defective tuner. It will not tune any digital channels.
I purchased two Samsung tuners that didn't work, the first didn't do QAM, the second seemed to just have a lousy tuner.
I now have a Channel Master 7001 which is tuning HD channels perfectly but won't tune any of the analog channels from the cable. I know they're there because the Samsungs tuned them. I've got my cable directly into a Sony LCD in my bedroom and it happily tunes both the analog and HD.
I thought the CM would do it all, anyone know if I could have a setting wrong? Else anyone know of a tuner that will tune both unencrypted analog and HD from cable?
Harrypt is offline
post #2 of 3 Old 03-21-2013, 10:52 PM
holl_ands's Avatar
Quoted: 440 Post(s)
Liked: 182
Specs for CM-7001 only says it supports ATSC and QAM....NTSC is missing from "Modulation Modes" list:
http://support.channelmaster.com/attachments/token/roxk1z5igcovvui/?name=CM7001+User+Guide.pdf
Also note that ALL CECB's, including CM7000 predecessor were NOT required to decode NTSC...which resulted in the "Analog Pass-Thru" design modification fiasco....
Searching through HD OTA STB list for "NTSC", you'll find they're fairly rare (e.g. Tivo, PrimeDTV, DVICO):
http://www.avsforum.com/t/179095/the-official-avs-hdtv-stb-synopsis
holl_ands is offline
post #3 of 3 Old 03-24-2013, 02:43 PM - Thread Starter
Harrypt's Avatar
Thanks for the info, it got me searching on a better track. Not many choices but there are some solutions out there.
FWIW, I don't understand why everyone likes this Channel Master box. It won't even let you delete unwanted channels... lame.
Harrypt is offline
Reply HDTV Technical
