Columbus, IN: Antenna suggestions for 50+ miles - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-31-2013, 05:05 PM - Thread Starter
hunterzach02's Avatar
I have been scouring the forums today looking for some suggestions but all the posts I came across were 4-6 years old. While looking through the information I think the Winegard HD7698P with a pre-amp may be the best choice but I want to make sure that there isn't something new out that may be a better fit. I plan on putting the antenna in the attic, it's large and spacious so it shouldnt be a huge issue. I am mainly interested in the channels to the north as the channels to the south do not cover any news/weather for my area. All the channels are UHF except for one of the ones I am interested in (WISH-TV, 9) which is VHF.
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda37a7f124e0
My end goal is to build out an HDHomerun setup but I need to run a proof of concept before dropping money on all the equipment.
hunterzach02 is offline
post #2 of 6 Old 03-31-2013, 07:22 PM
Otto Pylot's Avatar
Quoted: 1364 Post(s)
Liked: 854
I have a similar 28 year old Winegard that is slightly bigger (more active elements) for 50+ miles. Depending on your terrain and LOS, I'd suggest mounting it on your roof with a rotor, unless your house is a two-story but even then as high up as possible, and outside, will give you the best possible trouble-free reception.
Otto Pylot is offline
post #3 of 6 Old 03-31-2013, 08:21 PM - Thread Starter
HOA frowns upon antennas so the only option is in the attic. It is a two story house with 10ft ceilings though, house is less than 10 years old.
post #4 of 6 Old 03-31-2013, 09:28 PM
Otto Pylot's Avatar
Liked: 854
You might want to check into the legality of your HOAs restriction on outdoor antennas. Hopefully someone will post a link (I can't find it right now) but I don't think they can restrict outdoor antennas within reason. If you really want to use your attic I'd buy the antenna and try to hook it up to a small tv (portable) and see how the reception is before you invest in hardware (cables, connectors, etc).
post #5 of 6 Old 03-31-2013, 10:19 PM
rabbit73's Avatar
Quoted: 399 Post(s)
Liked: 159
FCC Over-the-Air Reception Devices Rule:
http://www.fcc.gov/guides/over-air-reception-devices-rule
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #6 of 6 Old 04-01-2013, 12:11 PM
kenglish's Avatar
Liked: 39
Your signals on most every station are going to be far too weak for any indoor antenna.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
Reply HDTV Technical
