No video output due to length of the HDMI cable ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 04-07-2013, 10:17 AM - Thread Starter
Lennert Smets's Avatar
Hello everyone,
I'm in the process of setting up my game room.
This is my current set-up
___________________________
Pioneer VSX-322
JBL in-ceiling speakers (4)
Yamaha Subwoofer
Acer P1220
Xbox 360 slim
The problem i'm running in to is the following:
The Pioneer receiver is hooked up to the acer Beamer with a 7m HDMI 1.4 cable. But since the receiver has a passive HDMI transmitter, the strength of the signal is reduced significantly to a point where it doesn't reach the beamer anymore (the sound kind of does, it get interupted, and some chokes of sound come through.
(if i hook my xbox directly to the beamer everything is just fine, and if i hook my xbox to the receiver and then to a LED-tv with a shorter HDMI cable everything works fine too.)
My first ideo to solve this was to get a HDMI-amplifier, but i can only get my hands on HDMI 1.3 amplifiers, which don't support ARC ( i need ARC to let the sound go through my audio system)
Any other idea's how i might be able to solve this, or might fix the problem?
Thanks in advance,
PS: Sorry if my english isn't quite that good, it isn't my native language.
Lennert Smets is offline
post #2 of 14 Old 04-07-2013, 11:09 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
You already have a thread started with the same question.
http://www.avsforum.com/t/1467160/no-video-output-due-to-length-of-the-hdmi-cable
Try this:
http://www.sears.com/shc/s/p_10153_12605_05702371000P?sid=IDx01192011x000001&kispla=05702371000P&srccode=cii_17588969&cpncode=31-114024720-2
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 14 Old 04-07-2013, 01:28 PM - Thread Starter
Oops! my bad, will delete it asap.
The extender that you are providing isn't the solution, my problem is that he signal doesn't reach my beamer for some reason, the cables are long enough.
post #4 of 14 Old 04-07-2013, 04:22 PM
Colm's Avatar
Liked: 94
Make sure Deep Color is turned off on the Xbox.
Make sure the HDMI cable you are using is certified high speed. There is no such thing as a HDMI 1.4 cable, just a standard HDMI cable and a high speed HDMI cable, with or without ethernet. If in doubt, ask the seller or manufacturer for the certificate for the cable from the ATC.
Colm is offline
post #5 of 14 Old 04-08-2013, 12:18 AM - Thread Starter
Thanks for the respons.
I'm 100% sure it's a high speed HDMI cable with ethernet , ARC, 4K and 3D support.
I'm also pretty sure the signal just doesn't reach the beamer due to signal loss caused by the receiver. (Like i said in the first post, when i hook them up directly without receiver everything works flawless.)
Any other idea's?
post #6 of 14 Old 04-09-2013, 07:43 AM - Thread Starter
bump
post #7 of 14 Old 04-09-2013, 08:17 AM
Otto Pylot's Avatar
Quoted: 1668 Post(s)
Liked: 1043
Try a Redmere High Speed cable. They are designed for use with lengths longer than 25' (you may be pushing that with an un-certified cable). Don't worry about ethernet because there aren't any consumer devices that support that feature.
Otto Pylot is offline
post #8 of 14 Old 04-09-2013, 08:17 AM
Ratman's Avatar
Liked: 1191
Okay... so you have a 23' HDMI. from the Acer to the receiver. How long is the hdmi from the receiver to the display device?
Your choices are:
Get a better (certified - 22 AWG) HDMi cable, such as:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024001&p_id=3990&seq=1&format=2
And/or try this:
http://www.monoprice.com/products/product.asp?p_id=2849&seq=1&format=2
Ratman is offline
post #9 of 14 Old 04-09-2013, 11:03 AM - Thread Starter
Some progress so far,
I got myself a repeater and it did some pretty weird things.
I plugged it in and out a few time in different places with no succes. Then i plugged it for one last time and i actually got an output image, then i chaned back to tuner to test if it was permanent and the signal was broken up again. but i am getting bits of sound through.
i also contacted Pioneer and they're saying that the receiver has a standard resolution output, and if this is to high for the beamer it wont display anything. i'm trying to change the resolution tomorow.
thanks for the replies so far, as for swapping the cable, it's tucked in the ceiling and a fake wall, so it would be a paint to swap.
thanks allot already!
keep the possible solutions comming
post #10 of 14 Old 04-10-2013, 07:58 AM
NetworkTV's Avatar
Quoted: 961 Post(s)
Liked: 1521
If you go that route, just make sure you pay attention to which way you connect it. The direction matters with those cables, which is why they work better over long distances.
NetworkTV is offline
post #11 of 14 Old 04-11-2013, 01:55 AM - Thread Starter
Update:
It's not the cable that is giving me a hard time.
The output resolution is 1080p, and the beamer can't handle this high resolution thus it refuses to give any output.
Is there any way i can change the output resolution?
i tried sending in a 640*400 resolution via my laptop but it looks like the receiver still boosts it to 1080p
thanks for the help so far!
post #12 of 14 Old 04-15-2013, 09:10 AM
Beerstalker's Avatar
Liked: 24
Sounds like you need to go into the settings on your Pioneer AVR and change the HDMI ouput scaling to max out at 1080i, or whatever your projector does accept. You might have to hook up the Pioneer with composite video cable to your projector, or bring in another tv that you could hook up to the Pioneer temporarily to change the video output settings on it.
Edit/
Upon looking up your Pioneer receiver it doesn't seem to do any kind of upconverting/upscaling at all, so it upscaling to some resolution your projector doesn't accept should not be the problem.
As far as needing ARC in the HDMI amplifier, why? ARC is for stuff like using the TV tuner, or apps built into a TV like Netflix. I don't think you rprojector has a tuner or any apps built into it, so there shouldn't be any audio coming out of it back to the receiver. To me an an HDMI amplifier between the Pioneer AVR and the projector seems to be about your only option (other than trying a different HDMI cable).
Beerstalker is offline
post #13 of 14 Old 04-15-2013, 11:36 AM - Thread Starter
Thanks for the reply,
the arc doesn't seem to be the problem. i tried hooking up an HDMI amplifier and it did nothing (it actually worked for about 2minutes but refused to afterwards). i also tried another cable with the same length of another manufacturer and the same thing was occuring. Seems like this setup doesn't like me.
post #14 of 14 Old 04-20-2013, 08:49 AM - Thread Starter
bump
Reply HDTV Technical
