TV and computer incompatible? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-08-2013, 06:50 AM - Thread Starter
dkomisar1's Avatar
I have a TV (Sharp Aquos 40") which I cannot get to work with a specific nettop. They both work fine with other devices. The TV says the signal is unsupported, won't even show during boot so I don't think it's an OS issue. Where do start debugging this?
Apologies if this doesn't belong here.
dkomisar1 is offline
post #2 of 5 Old 04-08-2013, 07:32 AM
sitlet's Avatar
Are you connecting with HDMI? Is the video card set to "Projector Only"? Is the resolution set correctly?
sitlet is offline
post #3 of 5 Old 04-08-2013, 07:39 AM
Selden Ball's Avatar
Quoted: 3300 Post(s)
Liked: 1614
What video connection are you using: HDMI or VGA?
What's the resolution and refresh rate of the computer's video output?
Some home entertainment devices (usually receivers, possibly some TVs) do not support the large variety of resolutions that computers can. Only "standard" entertainment resolutions work. e.g. 1080p (1920x1080 @60fps), 720p (1280x720), 480p (640x480. 854x480), etc. You might need to explicitly set the netbook's output video resolution to one of those.
Selden
Selden Ball is offline
post #4 of 5 Old 04-08-2013, 07:41 AM - Thread Starter
dkomisar1's Avatar
It's the onboard video for this crappy nettop, I'm not sure what it is. It has worked on other tvs though, but I'll check this.
post #5 of 5 Old 04-08-2013, 07:42 AM - Thread Starter
dkomisar1's Avatar
This is using hdmi.
I'm pretty sure it's set to standard 1080p but I could be wrong, another thing to double check. I'm not sure about refresh rate either, I'm pretty sure I've never set it explicitly anywhere.
Reply HDTV Technical
