3 HDMI devices, only 2 inputs - what to do? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-13-2013, 04:34 PM - Thread Starter
R o d's Avatar
My Denon receiver has two HDMI inputs and one output to my projector.
I want to connect a Tivo Premiere, Blu-ray player and Apple TV. I'm thinking to connect the BD player and ATV via HDMI and the Tivo via component video and audio. Does that sound right?
R o d is offline
post #2 of 5 Old 04-13-2013, 06:14 PM
UHD Addict
aaronwt's Avatar
Quoted: 5222 Post(s)
Liked: 3123
Just get an HDMI switch. You can get an auto switching one for only $10 from Amazon. Much better and easier to do that than go back to analog for video and optical for audio(or worse analog for audio).
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #3 of 5 Old 04-14-2013, 07:34 AM
Doctego's Avatar
Liked: 42
I use this switch:
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=8463&seq=1&format=2
Whatever you do, I would recommend getting a switch with a power cord and buying from somewhere that has a good return policy. I doubt that any switch for $10 will have a power cord. In that case, it gets power from the source and that can cause problems. HDMI is already finicky as it is.
Good luck.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #4 of 5 Old 04-14-2013, 08:20 AM
UHD Addict
aaronwt's Avatar
Liked: 3123
I use two, two port, auto switching HDMI switchers that have zero problems being powered with HDMI. I'm also using several Redmere cables with them which also need power. I run 3D. Deep color, and the advanced audio codecs. I have zero issues with them.
I also use a couple of the Monoprice five port HDMI switches. They work fine just like the auto switchers(except they don't auto switch). Although I think the LEDs are too bright from the Monoprice five port switches I have. But both types of switches work just as well for me.
aaronwt is offline
post #5 of 5 Old 04-14-2013, 09:16 AM
Doctego's Avatar
Liked: 42
I'm glad that they are all working for you. I am talking more in a general sense based on my research and trial and error. I find that a switch with an external power cord is a better option.
Doctego is offline
Reply HDTV Technical
