LG IR transmitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-16-2013, 06:40 PM - Thread Starter
mrgoodkat's Avatar
I bought an open box LG soundbar that did not include the IR transmitter extension. LG doesn't have a part number, etc. So is there a generic something that I can use? Would it have to be LG?
Thanks for any help!
mrgoodkat is offline
post #2 of 3 Old 04-17-2013, 05:54 AM
SAM64's Avatar
Liked: 78
It's an IR LED. Radio shack carries them.
SAM64 is offline
post #3 of 3 Old 04-20-2013, 09:14 PM
holl_ands's Avatar
Quoted: 564 Post(s)
Liked: 248
Users report that some IR Sensors (with 1/8-in Mini-jack and Cable) work with some, but not ALL equipments. A Dual-Frequency IR Sensor/Receiver may have better success, since the impulse response may be optimized for a variety of R/C Protocol data rates. Although a problem may be infrequent, be prepared to try different cables and return what doesn't work.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=ir+%2Breceiver&rh=n%3A172282%2Ck%3Air+%2Breceiver
holl_ands is offline
Reply HDTV Technical
