What's wrong with my setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-18-2013, 01:49 PM - Thread Starter
maxserg's Avatar
I've bought a CM-7777 titan2 antenna preamp and no channel goes to my tv set. If I bypass it, I can get around 16 HDTV channels.
I'tried the preamp near the antenna connectors(15 inches from the preamp). I did change cables for RJ-6, put a new 300/75 ohms transformator to my yagi Wineguard antenna.
I've measured voltage reading to the power to the preamp, it reads 21/22 volts dc so there is power there. I went to the dealer and he tried at his home and the preamp works in a similar situation.
Antenna without preamp, direct to the tv (42" plasma Panasonic) works but I know I could get 8/10 more channels.
Any clue?
maxserg is offline
post #2 of 3 Old 04-18-2013, 02:56 PM
reddog007's Avatar
TVFool report
For what we know that 8/10 more channels are in another direction and/or could be VHF.
How strong are your signals that you are currently getting?
Dealer tried the pre-amp and it didn't work at his house? Sounds broken to me.
reddog007 is offline
post #3 of 3 Old 04-19-2013, 08:24 PM
mikepier's Avatar
Quoted: 16 Post(s)
I agree, we need to see how strong your signals are. You could be overloading them.
mikepier is offline
Reply HDTV Technical
