I live 50 mile from Amarillo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-25-2013, 04:31 PM - Thread Starter
Archie54's Avatar
Our local TV stations broadcast HD but Dish converts them to SD and ABC's picture is over scanning by about 10% what chance do I have getting an OTA signal?
Archie54 is offline
post #2 of 7 Old 04-26-2013, 04:48 AM
mikepier's Avatar
Quoted: 16 Post(s)
Post your tvfool results so we can get an idea of reception in your area. Your address will not be shown.
mikepier is offline
post #3 of 7 Old 04-26-2013, 08:05 AM
mikepier's Avatar
Quoted: 16 Post(s)
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3D1ddab84ca74bc6
You can get the major networks with a VHF/UHF antenna pointing SW. The HBU-22 is one example of an antenna that would work.
Why does DISH convert your locals to SD? Do you have an HD DISH box?
mikepier is offline
post #4 of 7 Old 04-26-2013, 09:17 AM - Thread Starter
Archie54's Avatar
I don't know why Dish does this, KVII ABC has started broadcasting in 16:9 so we are getting severe over scanning, thanks for your help.
Archie54 is offline
post #5 of 7 Old 04-26-2013, 09:18 AM - Thread Starter
Archie54's Avatar
Yes I do have an HD Dish receiver.
Archie54 is offline
post #6 of 7 Old 04-26-2013, 12:55 PM
ADTech's Avatar
Quoted: 122 Post(s)
Liked: 65
Most likely. due to bandwidth constraints in their system.
Tech support for Antennas Direct
ADTech is offline
post #7 of 7 Old 04-28-2013, 10:50 AM
Speed Daemon's Avatar
Quoted: 91 Post(s)
Liked: 47
Hey Archie54, do you know where Dimmitt is?
My grandparents and other family lived there through ~1980. Dimmitt is about 90 miles from Amarillo and Lubbock, and just about everybody in town had a deep fringe antenna on a 20 foot (or more) tower. I have fond memories as a child of playing with my grandpa's antenna rotator, looking for something other than "wrastlin'" to watch.
Although 50 miles is a lot less than 90 miles, if I was in your boots I'd put up a tower if at all possible. Cutting out the ground clutter will solve your problem a lot quicker than any fancy antenna. You'll still need a highly directional antenna, and maybe some amplification. But IME it's the elevation that makes the difference between you getting a good stable OTA signal and pulling your hair out every time a truck passes. Good luck!
You get what you pay for.  For professional advice, pay the professional rate.
Speed Daemon is offline
Reply HDTV Technical
