Help with Antenna Selection in MS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-26-2013, 10:40 AM - Thread Starter
hank89's Avatar
Could someone please advise me on a good make/model antenna I should purchase for the following address:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda35aad64adb
Thank you!
hank89 is offline
post #2 of 3 Old 04-26-2013, 12:54 PM
mikepier's Avatar
Quoted: 16 Post(s)
You need a VHF/UHF antenna. You are close to the towers, you should not need anything big. You could maybe get away with an indoor antenna like this:
http://www.radioshack.com/product/index.jsp?productId=2103077&znt_campaign=Category_CMS&znt_source=CAT&znt_medium=RSCOM&znt_content=CT2032189
The antenna should be facing primarily South. Most of your channels are to the SW, but ABC is the oddball to the SE. So if you split the difference and point South, you should be ok.
If you have problems with reception, you can try to install the indoor antenna in a high spot like in the attic. Otherwise try an outdoor antenna like the HBU-22 in the attic or outside.
mikepier is offline
post #3 of 3 Old 04-26-2013, 02:58 PM - Thread Starter
hank89's Avatar
Thanks Mike!
hank89 is offline
Reply HDTV Technical
