OTA DVR & TV Guide Help - AVS Forum | Home Theater Discussions And Reviews
Old 04-26-2013, 11:39 AM - Thread Starter
EpicVegas's Avatar
Im going to cut the cable soon & plan on buying a outdoor antenna and replace the DirecTV satellite with it after I cancel my service. Ill be splitting the signal to each room the same way DirecTV is split to each room.
My question is how do I get a TV guide on the TVs in each room & what is the best way to setup a DVR on My HTPC?
I have a Roku 3 that I would like to watch my DVR shows on if possible
EpicVegas is offline
Old 04-26-2013, 02:43 PM
myoda's Avatar
Liked: 57
To get guide data on each TV, you would need a pc at each TV, running Windows 7 Media center, a box (or 2) from Silicon Dust, an antenna feed, and ideally a wired network connection at each location.
http://www.silicondust.com/products/hdhomerun/atsc/
Since you have rg6 cabling already run from an existing sat feed, it should not be a problem getting signal to the Silicon Dust boxes. Each of the HDHomeRun boxes have 2 tuners in them so you can record 2 shows at the same time, and access them over the network. I have a PC in my basement, and I store recorded content on a 3 TB hard drive. The only downside is finding time to watch everything..biggrin.gif
myoda is offline
