Antenna A will not show picture or sound or menu - AVS Forum | Home Theater Discussions And Reviews
Old 05-14-2013, 11:14 AM - Thread Starter
cadencemp3's Avatar
I have a pdp5080hd. When i go to my hdmi inputs and components everything works fine. When i go to antenna a to watch tv my screen is blank, no volume, channel, or anything. I cant get to the menu or anything like that. If someone could help on what to do i would greatly apprecitate it thanks!!!
cadencemp3 is offline
Old 05-14-2013, 11:27 AM
holl_ands's Avatar
Quoted: 436 Post(s)
Liked: 179
Are you missing the Remote control??? If you can't get to the menus, either you need to carefully reread the User's Guide or your firmware needs to be reloaded. Let's hope it's something simple:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/477134695PDP5080HDOperatingInstructions0807.pdf
holl_ands is offline
Old 05-14-2013, 11:55 AM
rabbit73's Avatar
Quoted: 399 Post(s)
Liked: 159
Did you set the Mode switch at the bottom of the remote control to TV?(p15)
Are you trying to watch TV chanels from cable or antenna?
Have you done a channel scan using Auto Channel Preset?(p37)
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
