"Your TV does not support this program's content protection" error message from Directv - NEED HELP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-15-2013, 08:37 AM - Thread Starter
shiv09uf's Avatar
I just purchased a new Sony KDL-R550A LED tv and when I installed it got the error message "Your TV does not support this program's content protection" for my premium channels (HBO, Showtime, etc.).
My setup is pretty simple:
Direct TV box HDMI directly to the TV.
Blu ray player HDMI directly to the TV.
Digital Optical Out to Sony HTCT260 soundbar.
The TV I had there previously, and older Samsung LED TV along with the Sony HX800 downstairs with a Sony HTCT150 soundbar work perfectly fine.
I have paid subscriptions to all these channels and was wondering how I can fix this issue. I've been able to google some solutions but they always seem to include adding component cables. I would much prefer to continue to use HDMI cables. Also my TV is brand new so I would hope it would be compatible.
Appreciate the help!
shiv09uf is offline
post #2 of 6 Old 05-15-2013, 10:50 AM
Otto Pylot's Avatar
Quoted: 1596 Post(s)
Liked: 1001
Do you have other HDMI cables that you could try out? What kind of cables are you currently using? If it's the HDMI cable, Certified High Speed HDMI should correct the issue if it's an HDCP problem.
Otto Pylot is online now
post #3 of 6 Old 05-15-2013, 11:22 AM - Thread Starter
shiv09uf's Avatar
The thing was that it worked, then when I turned off the tv and receiver it stopped working. I did some unplugging and re plugging in and it worked again. I also replaced the HDMI cables intermittently and it worked. I just really hope it's not an issue I should expect consistently.
shiv09uf is offline
post #4 of 6 Old 05-15-2013, 11:42 AM
Thread Ender
WS65711's Avatar
Quoted: 509 Post(s)
Liked: 341
If you replace the HDMI cable permanently, does it work intermittently or permanently? confused.gif
Have you tried changing the power-on sequence of the affected devices?
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #5 of 6 Old 05-15-2013, 12:14 PM - Thread Starter
shiv09uf's Avatar
Last night I changed the HDMI and it worked fine. Previously it worked with a random assortment of powering on/disconnecting the previous HDMI cable.
I've heard about the power on sequence, but wasn't sure how to change it using the Directv remote.
shiv09uf is offline
post #6 of 6 Old 05-27-2013, 08:43 PM
garnettrules21's Avatar
Quoted: 60 Post(s)
Liked: 61
I am all of a sudden getting this message on my samsungd450 plasma. TV is like a year old, latest firmware. Not sure what the deal is.
PSN: RetroGiant
garnettrules21 is offline
Reply HDTV Technical
