2 x 1 splitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-17-2013, 03:40 AM - Thread Starter
Noel8's Avatar
I have cable box with one hdmi output which is occupied from my blu-ray player. How can I get HDMI connection from that cable box to my HDTV 55" set? Would a HDMI splitter work as well? i see on ebay they are selling them like $6 or so. Is there something i should look for with problems that some HDMI cables are erratic?
Noel8 is offline
post #2 of 4 Old 05-17-2013, 04:48 AM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
Why do you need a HDMI cable going from your cable box to your blu-ray player? I think you mean that your TV only has one HDMI input and you need to connect multiple HDMI devices. If this is the case then a HDMI switch will work just keep your cables as short as possible.
RollTide2011 is offline
post #3 of 4 Old 05-17-2013, 07:05 AM
sitlet's Avatar
Quoted: 14 Post(s)
If you want to take two hdmi devices into one hdmi input, you need an hdmi switch, not a splitter. Monoprice has a few of them.
sitlet is offline
post #4 of 4 Old 05-17-2013, 07:09 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
What you need is an HDMI switch that lets you select between the 2 sources which one goes to the TV. Monoprice has a good, auto-sensing one for ~$11. http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011001&p_id=8150&seq=1&format=2
An HDMI splitter is designed to distribute an HDMI signal to 2 different display devices. Unlike r.f. splitters, they can't just be turned around.
CIAO!
Ed N.
egnlsn is offline
Reply HDTV Technical
