Audio issue with HDMI - AVS Forum | Home Theater Discussions And Reviews
Old 05-21-2013, 11:45 AM - Thread Starter
griffiththeplay's Avatar
Hello -
I have a SONY Bravia and am having difficulty getting audio when using HDMI output. I can get video just fine from my Laptop - just no audio. Any suggestions? Thank you
griffiththeplay is offline
Old 05-21-2013, 01:31 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Are you sure that your laptop output is HDMI (and not DVI) ?? DVI has no audio.
domino92024 is offline
Old 05-21-2013, 06:33 PM - Thread Starter
Thanks -
It definitely has the hdmi output... does the DVI output look any different than the hdmi? Is there a way to tell if I have DVI vs. hdmi?
thanks
Old 05-21-2013, 09:52 PM
Doctego's Avatar
Liked: 42
Try going into the control panel on the laptop and clicking SOUND. See what the setting is. Try changing it to HDMI.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
