Snow when I change channels. HDMI? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-28-2013, 06:21 PM - Thread Starter
bjjp2's Avatar
Hi. Have a Samsung UN55D6000 TV and a Pioneer VSX-821 receiver. When I change channels I frequently get a screen filled with snow. Turn the TV off and on again and picture is back. I assume this is some kind of HDMI handshake issue. Have tried replacing HDMI cables. Any tips or suggestions? Thanks.
bjjp2 is offline
post #2 of 5 Old 05-29-2013, 04:02 AM
Ratman's Avatar
Quoted: 1303 Post(s)
Liked: 1041
Bypass the Pioneer and connect directly to the TV. If problem persists, it may be a cable box or TV problem.
If problem stops, look to the Pioneer as suspect.
Ratman is online now
post #3 of 5 Old 05-29-2013, 08:57 AM - Thread Starter
bjjp2's Avatar
Thanks for your help. I bypassed the Pioneer and the problem appears gone. So any idea how to fix the issue with the Pioneer short of getting a new receiver?
bjjp2 is offline
post #4 of 5 Old 05-30-2013, 07:55 AM
Ratman's Avatar
Liked: 1041
Assuming you are using a cable box, my first thought would be to verify the video output settings of the cable box. Set the video resolution to always output 1080i. If it's set to send "natiive", perhaps the changes of the channels from 480i, 720p to 1080i confuses the sync between the STB, receiver and the TV.
Also, if the receiver has any video settings, do the same. Set to fixed 1080i.
post #5 of 5 Old 10-21-2013, 04:36 PM
josephragland's Avatar
Thank you very much.
josephragland is offline
Reply HDTV Technical
