How do i stop this. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-03-2013, 07:58 AM - Thread Starter
420 benz's Avatar
Every time i turn on the TV this pops up.How can i remove it?
420 benz is offline
post #2 of 8 Old 06-03-2013, 09:09 AM
sitlet's Avatar
Quoted: 16 Post(s)
Have you tried doing a factory reset through the menu? Or just unplug the power for a few minutes.
sitlet is offline
post #3 of 8 Old 06-03-2013, 09:18 AM - Thread Starter
420 benz's Avatar
No but I will. BTW: Where is it coming from?
420 benz is offline
post #4 of 8 Old 06-03-2013, 03:18 PM - Thread Starter
420 benz's Avatar
Did not work. Any more suggestions?
420 benz is offline
post #5 of 8 Old 06-03-2013, 03:40 PM
Dropkick Murphy's Avatar
Quoted: 72 Post(s)
Liked: 89
Do you have Verizon Fios?
If so, use your Verizon remote and press MENU
Go to SETTINGS
Go to TELEVISION
Go to PROMOTIONS and disable
Dropkick Murphy is offline
post #6 of 8 Old 06-03-2013, 04:46 PM - Thread Starter
420 benz's Avatar
No I don't .
420 benz is offline
post #7 of 8 Old 06-03-2013, 06:13 PM
ProjectSHO89's Avatar
Quoted: 288 Post(s)
Liked: 131
Call either the TV manufacturer's customer support or perhaps your cable company.... It's probably a built-in app in your TV (which you didn't bother identifying). Try checking the owner's manual for the TV set for info about the 'MTV Music Meter" app. For example, see http://www.samsung.com/us/article/know-your-apps-mtv-music-meter
When in doubt, read the manual.
ProjectSHO89 is online now
post #8 of 8 Old 06-05-2013, 04:54 PM
Super Moderator
DrDon's Avatar
Quoted: 1322 Post(s)
Liked: 2565
DrDon is offline
Closed Thread HDTV Technical
