Buy Clear TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-16-2013, 12:14 AM - Thread Starter
donaldsonjune's Avatar
Quoted: 41 Post(s)
hello all,
anyone tried this http://www.cleartv.com/
June
"IF YOU FAIL TO PLAN, YOU PLAN TO FAIL"
donaldsonjune is offline
post #2 of 4 Old 06-16-2013, 05:04 AM
ProjectSHO89's Avatar
Quoted: 211 Post(s)
Liked: 110
It's an inexpensive flat UHF antenna. Don't get your expectations too high unless you're in a very easy receiving location. Don't expect good reception of Philly channels 6 & 12.
ProjectSHO89 is offline
post #3 of 4 Old 06-17-2013, 11:58 AM
tylerSC's Avatar
Quoted: 724 Post(s)
Liked: 166
Don't know if it's as good as the Mohu Leaf or Winegard Flatwave. But definitely cheaper. Also, the HD Blade from Solid Signal is the same as the Winegard Flatwave, but cheaper.
tylerSC is offline
post #4 of 4 Old 06-18-2013, 08:05 AM
kenglish's Avatar
Liked: 39
They are probably all about the same. Just a basic Triangular Dipole, with no reflector or director elements, so it's bi-directional.
Not any real signal gain over any other dipole.
I have a similar one, but haven't tried it out yet (just added to my collection).
I'd go with one like this in the city, if I didn't have room for something like a (directional) Silver Sensor to sit somewhere. These can go up high on a wall, or in a window.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
Reply HDTV Technical
