TV Fool Down? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-26-2013, 08:59 PM - Thread Starter
Mister B's Avatar
Quoted: 17 Post(s)
I have tried to use TV Fool several times in the past week. I always get a message that the address can not be resolved and the Longitude is out of range. The last time I checked El Paso, Texas is still on the map. Is anyone else having similar problems?
Mister B is offline
post #2 of 5 Old 06-26-2013, 09:01 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Find out for yourself: http://www.isitdownrightnow.com/
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 5 Old 06-26-2013, 09:17 PM - Thread Starter
Mister B's Avatar
Quoted: 17 Post(s)
This tool states the site is up. But of course, I can go to their web page. It just will not accept addresses that I know are absolutely valid.
Cabal0 likes this.
Mister B is offline
post #4 of 5 Old 06-26-2013, 09:24 PM
holl_ands's Avatar
Quoted: 437 Post(s)
Liked: 180
Someone reported that TVFool was exceeding some sort of Google look-up limit for address to LAT/LONG conversion.
Try entering your LAT/LONG instead....
In Google Maps enter your address, Right-Click on the Pushpin, then select "What's Here" to see LAT/LONG in search entry box.
holl_ands is online now
post #5 of 5 Old 06-26-2013, 10:00 PM - Thread Starter
Mister B's Avatar
Quoted: 17 Post(s)
That works! Thank You.
Mister B is offline
Reply HDTV Technical
