Help with DirecTV at my vacation home - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-28-2013, 07:52 PM - Thread Starter
jmpellet's Avatar
I have a vacation home where I want to bring back and forth my HR24 receiver. I think the extra dish I have is a SWM with the 3 style LNB? See pictures below.
Do I need to buy a single LNB now that I only need one cable in or can I use the existing dish as is? The installer at my primary home said I could use the existing dish but just one cable. If that's the case which do I choose? Or, do I need to buy:
DIRECTV SL3-SWM SlimLine Single Wire Ka/Ku Triple LNB With Built-In Multiswitch
http://www.amazon.com/DIRECTV-SL3-SWM-SlimLine-Built-In-Multiswitch/dp/B003ZT28GC/ref=pd_sim_e_2
I am also wondering which power inserter I need and if this dish will even work. I need a run in excess of 100 feet so do I need the unit with 29 volts vs. 21?
http://www.amazon.com/DIRECTV-PI-29Z-Power-Inserter-SWM-LNB/dp/B003C292AC/ref=sr_1_2?ie=UTF8&qid=1372473859&sr=8-2&keywords=directv+power+inserter
Thank you from a newbie!!
jmpellet is offline
post #2 of 2 Old 07-01-2013, 08:57 AM
Super Moderator
DrDon's Avatar
Quoted: 1321 Post(s)
Liked: 2564
1) What you're asking is against your TOS with DirecTV. Your receivers are for use only at the address associated with your account.
2) That said, there's a whole massive DirecTV catch-all thread in the HDTV Programming section where you're more likely to get a fast answer.
With the 5 LNB dish in the photo, you'll need two cables for dual tuner functionality IIRC. With the SWM dish, you'll only need one cable, but if you're a fan of any of the music channels carried on the 119 bird, or any of the ethnic channels you'll lose those (lesson I learned the hard way).
Again, those guys in the DirecTV thread are savants at this sort of thing. Post there.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Closed Thread HDTV Technical
