DirecTV HD box and older HDTV without HDMI port - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-02-2013, 12:51 PM - Thread Starter
vmoness's Avatar
Hello,
I have DirecTV HD boxes. One of my tv's is older so although it is an HDTV, it does not have an HDMI port. The DirecTV HD boxes have the HDMI port to hook up to tv. Will it work if I buy an HDMI to 3 RCA cable? TIA
vmoness is offline
post #2 of 11 Old 07-02-2013, 08:15 PM
McDonoughDawg's Avatar
Quoted: 20 Post(s)
Liked: 31
No component hookups?
Peachtree City Golf Cart Rider
McDonoughDawg is offline
post #3 of 11 Old 07-02-2013, 10:11 PM - Thread Starter
vmoness's Avatar
Not sure what you mean exactly but there isn't another way to hook up to the box. I did see what looks like an AV plug in on the box but I bought that cord and it was not a fit.
vmoness is offline
post #4 of 11 Old 07-03-2013, 05:56 AM
Quoted: 20 Post(s)
Liked: 31
You can pass HD two ways as far as I know, HDMI and Component Video (red, blue, green cable). Does your box offer that output?
Not sure of an adapter, i would check Monoprice.com if the box only offers HDMI output.
post #5 of 11 Old 07-03-2013, 05:58 AM
Awenta's Avatar
Can we have a picture or model numbers of both?
What inputs are available on the tv?
Awenta is online now
post #6 of 11 Old 07-03-2013, 07:45 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Could it be a DVI port if it is they sell HDMI cables with DVI on one end.
joed32 is offline
post #7 of 11 Old 07-03-2013, 10:01 AM
Quoted: 20 Post(s)
Liked: 31
Yes, DVI makes 3. I had one years ago and forgot about it.
post #8 of 11 Old 07-04-2013, 08:15 AM
RoyGBiv's Avatar
Quoted: 75 Post(s)
Liked: 35
All of DirecTV's HD boxes also have component outputs. The newer ones that don't appear to, require an adapter which is available from DirecTV to do so. Any HDTV has either HDMI or component inputs and almost all have both. Older TVs which don't have HDMI inputs have to have component inputs as that is the only other way to get an HD signal to the TV.
SMK
RoyGBiv is offline
post #9 of 11 Old 07-04-2013, 08:36 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
SMK
Except for DVI if the set is really old.
joed32 is offline
post #10 of 11 Old 07-04-2013, 11:00 AM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
If the OP would tell us what receiver he has, we could answer the question......
texasbrit is offline
post #11 of 11 Old 07-09-2013, 10:48 AM
Beerstalker's Avatar
Liked: 24
I'm going to guess he has either a H25, or a C31/C41. If he has any of these he needs one of these two cables:
If his TV is HD, or if he has an older SD TV with component vidoe inputs then he should get this one.
http://www.amazon.com/Directv-H25-Component-Video-Cable/dp/B006R9O2PC/ref=sr_1_1?s=electronics&ie=UTF8&qid=1373388464&sr=1-1&keywords=directv+component+cable
If his TV is and old standard def one without component then he needs this composite video adapter. If his TV doesn't have composite video input either then he will need to pair this cable with an RF modulator.
http://www.amazon.com/Directv-Dtv-Pin-Composite-Only/dp/B00BDXBBJ2/ref=sr_1_1?ie=UTF8&qid=1373388228&sr=8-1&keywords=directv+composite+cable
http://www.amazon.com/Audiovox-Corporation-CRF907R-Compact-Modulator/dp/B0014KKV7W/ref=pd_sim_misc_5
Ignore the fact that the listings say H25 or C31 only. Both cables will work with any of the H25, C31 or C41 boxes.
Beerstalker is offline
Reply HDTV Technical
