Best indoor HD antenna to get local stations? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 101 Old 01-18-2014, 09:16 AM
T/O
T/O's Avatar
Originally Posted by ProjectSHO89 View Post
Since you will have to rely on either reflections off other buildings or whatever signals might penetrate your concrete and steel box, odds are poor that anything will work reliably. Often, if you're on the wrong side of the building in such a situation, you're often facing very long odds.
Guess that's my luck in a nutshell
T/O is offline
post #62 of 101 Old 01-18-2014, 07:01 PM
deltaguy's Avatar
Quoted: 17 Post(s)
Originally Posted by T/O View Post
Hi all;
Guess I'll join the party and ask for help. I'm on the top floor of a building with concrete floors and ceiling. My tv is on the north end of the room and my only window faces east.
here is my TVfool report
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d5b947ac2e15a6f
Looking for indoor only as outdoor is prohibited in my co-op
Thank you
An unamplified rabbit ear/loop is the best starting point for indoor reception. If you can, try it without the rabbit ears first. See how the antenna does with the UHF channels. Then, add the rabbit ears for the VHF channels. Buy from a vendor that allows returns. The best antenna is one that works for you, no matter what style. Good Luck.
deltaguy is offline
post #63 of 101 Old 05-01-2014, 01:28 PM
Raff30's Avatar
Hi all - I know it's been a while since anyone commented on this thread - but - here's mine... suggestions?
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de1c6462c5d0bee
Thanks in advance - WLUK (FOX) is what really matters (VHF) - as it covers most of the local Packer game coverage
Raff30 is offline
post #64 of 101 Old 05-01-2014, 09:18 PM
ctdish's Avatar
Quoted: 60 Post(s)
Liked: 34
Deltaguy's answer in the previous post covers your situation too. Especially the part about using rabbit ears for VHF.
John
ctdish is offline
post #65 of 101 Old 05-01-2014, 10:36 PM
deltaguy's Avatar
Quoted: 17 Post(s)
If WLUK is the only channel having problems, electrical interference is a likely cause. Beware of your tv, lights, laptop, or many other devices. Turn them off to ensure they are not stopping VHF reception. Buy from a vendor that allows returns. Antenna location/height/aim are the key. Let us know what you try and results. Good Luck.
deltaguy is offline
post #66 of 101 Old 05-12-2014, 07:07 AM
CheYC's Avatar
Quoted: 35 Post(s)
Liked: 56
So I'm looking to get rid of cable altogether and just want the local stuff, I've got no clue what kind of antenna to get. I know I want indoor, was looking at this:
http://www.amazon.com/AmazonBasics-Ultra-Thin-Indoor-Antenna/dp/B00DIFIM36/ref=sr_1_2?s=electronics&ie=UTF8&qid=1399899463&sr=1-2&keywords=tv+hd+antenna
Here's my tvfool report:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de1c6aeea838067
CheYC is offline
post #67 of 101 Old 05-12-2014, 07:50 AM
Raff30's Avatar
Ended up getting what was recommended earlier in the thread - one for each TV (could have split it, but for $30, just bought 2).  Works excellent!
http://www.walmart.com/ip/GE-Amplified-Antenna/20976616#ProductDetail
Raff30 is offline
post #68 of 101 Old 05-12-2014, 10:29 AM
tylerSC's Avatar
Quoted: 708 Post(s)
Liked: 166
Apparently the GE 34763 Antenna is a good performing indoor antenna, and one of the better flat panel type choices. But interesting that it has a more elongated design rather than square. Perhaps it contains rabbit ears inside, as well as some UHF loops. But one of the tech engineers has recommended it as performing well in field testing. And $29 at Walmart is certainly more reasonable than a $79 Mohu or various Flatwave versions.
tylerSC is offline
post #69 of 101 Old 05-12-2014, 03:49 PM
retiredengineer's Avatar
Quoted: 31 Post(s)
Liked: 24
I had a TERK AM/FM amplified tower antenna that wouldn't pick-up FM stations. I took it apart and found a small circuit board and an attached wire about 12 inches long running up the tower. The wire was the FM antenna. Given the dimensions of the GE antenna, I bet the actual antenna is a single long wire attached to an amplifier. Since the original poster is close to the transmitter antennas and has line-of-sight, any indoor antenna would have worked.
retiredengineer is offline
post #70 of 101 Old 06-07-2014, 09:54 PM
unsmiley's Avatar
Quoted: 26 Post(s)
Would like everyone's opinion on an indoor antenna for me.  I live on the 12th floor, windows face north.  I use a 99 cent rabbit ears and loop (no amplification), and get most things, but I am looking to get WLIW 21.1 and WLNY 55.1 OTA if at all possible.  And my WNJN 50.1 reception is very poor.
TV fool report, which I do not really understand, is below:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de1c62a351ac88e
Thanks for any help.
unsmiley is offline
post #71 of 101 Old 06-07-2014, 10:11 PM
LastButNotLeast's Avatar
Quoted: 1442 Post(s)
Liked: 1027
Stations in the green section are the easiest to receive.
When you get the the yellow section (where you'll find 21.1), reception is harder, meaning you would need a larger/better/higher/directional antenna.
In the red section (where, unfortunately, 55.1 is), reception will be substantially more difficult.
The same report on antennaweb.com lists NEITHER station :(
http://www.antennaweb.org/Stations.aspx?Address=&City=New+York&State=NY&ZIP=10028&Housing=M&Accuracy=4&Height=9&Obstructed=False&StationList=&Lat=40.7766412&Lon=-73.9521468
So it looks like your 99 cent wonder is doing as well as anything else.
You might be able to get more help here:
http://www.avsforum.com/t/275729/new-york-ny-ota
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #72 of 101 Old 06-08-2014, 02:36 PM
unsmiley's Avatar
Quoted: 26 Post(s)
Thanks for the info.  But does that mean that an simple (or fancy) "amplified" indoor antenna will not help me get any of those three stations (21.1, 55.1, or 50.1)?
unsmiley is offline
post #73 of 101 Old 06-08-2014, 03:17 PM
Liked: 1027
That's right. You're just amplifying a lousy signal. You need a good directional antenna to get those, which you're probably not going to want indoors. ;)
post #74 of 101 Old 06-10-2014, 10:22 AM
DrLar's Avatar
Quoted: 438 Post(s)
Liked: 230
I hope this is the right thread all the talk about different indoor antennas.
What about a big building like a factory? that's currently has windows facing the opposite side of the transmitters (tough luck IMO), any indoor antenna that could help?
My TV Fool report
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de1c60aaaad63a5
The building is about 24ft high, with metal roof and concrete walls, and installing an outdoor antenna is no option.
The report says green all over but believe me, no TV here can get anything with the rabbit ears I tried (the only one I had to test)
RIP Mom, we always love you 8/18/13
DrLar is offline
post #75 of 101 Old 06-10-2014, 04:28 PM
rabbit73's Avatar
Quoted: 386 Post(s)
Liked: 145
DrLar:
Your building sounds like a shielded enclosure that blocks signals.
It looks like your location is SE of El Paso, near the intersection of US10 and route 375, maybe between Gateway Blvd and Rojas Dr.
If there are no windows on the west wall to put an inside antenna, you have a difficult problem.
Any windows on the north wall that can see the transmitters?
Unless you can mount a single UHF bowtie antenna without reflector outside the west wall and run the coax through a hole in the wall, you are probably out of luck. A UHF bowtie antenna would be less than 20 inches long; a UHF folded dipole would be less than 10 inches long.
There is a remote possibility that you can mount a 4-bay UHF bowtie antenna inside a window on the east wall and aim it at a building that will reflect signals coming from the west.
If your windows have low-e glass, it might block the signals, as would metal screening.
An extreme solution would be to mount an antenna on your parked car with a tuner and a GHz RF link to relay the signals to an RF link antenna in an east window.
I would need to see an aerial view of the building to give a more specific answer. If you care to give me the exact address of the building by PM, I can study it. I would need your permission to post a photo of a solution, if one exists.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #76 of 101 Old 06-10-2014, 11:07 PM
deltaguy's Avatar
Quoted: 17 Post(s)
My TV Fool report
Have the rabbit ears been tried near a window? I ask because most indoor antennas have short cables. Your PBS station broadcasts on VHF which rabbit ears often receive. The location, height, and aim indoors can be absolutely critical for reception. I have signal blocking insulation in the walls and attic here, but have managed VHF reception in rooms with windows facing the wrong way. The signals here are not as strong as PBS on your TVFool report.
deltaguy is offline
post #77 of 101 Old 06-12-2014, 07:43 AM
DrLar's Avatar
Quoted: 438 Post(s)
Liked: 230
Thanks for the replies.
We have a couple of windows facing NE, I went there with a small TV and rabbit ears, it worked well...
Our problem is they want to air the World Cup in the middle of the shop floor, which is far from the windows.
We are thinking of buying an aerial antenna, put it someplace on the west side, run coax through the building where the big screen is going to be. What's the max distance you could run coax with not much loss? say it maybe be 100ft from the west wall to the TV's location.
DrLar is offline
post #78 of 101 Old 06-12-2014, 04:57 PM
ProjectSHO89's Avatar
Quoted: 200 Post(s)
Liked: 108
With an outdoor antenna, you should have plenty of signal for up to several hundred feet of coaxial cable without any amps.
ProjectSHO89 is offline
post #79 of 101 Old 06-13-2014, 12:04 AM
deltaguy's Avatar
Quoted: 17 Post(s)
If PBS isn't important, an outdoor UHF antenna near the window you tested would likely out perform the rabbit ears you've tested already. 2, 4, and 8 bays are available.
deltaguy is offline
post #80 of 101 Old 06-15-2014, 02:09 PM
unsmiley's Avatar
Quoted: 26 Post(s)
How about something unobtrusive on my north-facing terrace? Would that pull in WLNY 55.1 and or WLIW 21.1?
unsmiley is offline
post #81 of 101 Old 06-16-2014, 09:16 AM
Crazy Serb's Avatar
how about this one?
http://www.tvfool.com/?option=com_wr...e1c6afb6c39d3e
I'm in Toronto, on the 24th floor, facing south/west...
what would work for me?
Crazy Serb is offline
post #82 of 101 Old 07-06-2014, 06:23 PM
Keith Lashinski's Avatar
http://www.tvfool.com/?option=com_wr...e1c6f728bb515b
Here are my results. Looking for a simple antenna to get local channels( ABC, CBS, NBC, etc). Suggestions? TV is on the second story of a 2 story house. Very hilly in the area.
Keith Lashinski is offline
post #83 of 101 Old 07-07-2014, 05:44 AM
Quoted: 200 Post(s)
Liked: 108
Other than those two translators in your back yard, the odds of reliable reception with an indoor antenna are probably negligible.
post #84 of 101 Old 02-11-2015, 04:52 PM
Liked: 2
Hi all,
I'd like to ask for help. I recently pick up one of these (sorry cannot post links yet)
amazon.com/gp/product/B000GIT002/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Is it sufficiently enough or I could do better with something else according to my place.
tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d2c15b99410c87 8
Thank you
olegg is offline
post #85 of 101 Old 02-11-2015, 05:06 PM
Skeletor's Avatar
Same question as everyone else here. Here are my results.
http://www.tvfool.com/?option=com_wr...2c15da873f58c7
Obviously I'd like something small that can go behind the TV or on the entertainment center if at all possible.
Skeletor is offline
post #86 of 101 Old 02-12-2015, 09:56 AM
holl_ands's Avatar
Quoted: 420 Post(s)
Liked: 178
Skeletor: You have VERY high signal levels that prevent use of AMPLIFIED Antennas. You can use either a Directional Antenna...or a Bi-Directional Antenna.
olegg: Your signals levels are only a bit lower, so I advise against AMPLIFIED Antennas. You need a Bi-Directional Antenna.
Unfortunately Terk HDTVi and other similar NON-Amplified DIRECTIONAL Antennas are nearly impossible to find anymore.
I suggest BOTH of you try a simple NON-Amplified VHF-Rabbit-Ears+UHF-Loop...even the cheapest should get the job done.
Although the Hi-VHF performance is much less than Rabbit-Ears, you could also try a NON-Amplified FLAT Antenna, such as Mohu Leaf, Winegard FlatTenna, RCA Flat Panel, WallTenna (incl. MODS), etc, which can be mounted on the WALL, including hiding it behind a Picture:
I'm still using rabbits ear antenna for my HDTV, need better stronger Antenna signal
BTW: Mounting it inside a Metal Picture Frame can actually Improve Hi-VHF Performance, see Optimized results for WallTenna Modifications:
http://imageevent.com/holl_ands/mult...naenhancements
Fol. OPTIMIZED DIY 2-Bay Bowtie with Rectangular Loop (RLH2) performs well in BOTH UHF and Hi-VHF, running circles around any Commercial Flat Panel or Rabbit-Ears Antennas. Can be hidden behind a Picture on the Wall...but if using a METAL Frame, it should be very close to size determined by the Optimizer:
http://imageevent.com/holl_ands/loops [RLH2 is near the Bottom]
If you bury the Antenna behind HDTV or equipment the signals will be blocked...so try to place it AWAY from equipment as much as possible.
holl_ands is offline
post #87 of 101 Old 02-12-2015, 10:21 AM
Liked: 2
Originally Posted by olegg View Post
Hi all,
Thank you
Anybody?
olegg is offline
post #88 of 101 Old 02-12-2015, 10:47 AM
richart's Avatar
Quoted: 88 Post(s)
Liked: 32
Anybody?
Is this your TV Fool report?
http://tvfool.com/?option=com_wrappe...2c15b99410c878
It would help everyone to determine if the antenna you mentioned would work if you could tell us which stations you want to receive. The report about has stations coming from several different directions.
Also, if you start a new thread and follow these instructions you will probably get a lot more responses to your questions.
richart is offline
post #89 of 101 Old 02-12-2015, 12:36 PM
holl_ands's Avatar
Quoted: 420 Post(s)
Liked: 178
Eagle Aspen 2-Bay is UHF ONLY, with only minimal Hi-VHF Gain, mostly to the REAR.....it appears that you need a Low-Gain, Bi-Directional Antenna(s) for BOTH UHF and Hi-VHF to cover all THREE Directions: 99, 154 and 295-326 degrees (re True North), as I described above.
post #90 of 101 Old 02-12-2015, 06:01 PM
Skeletor's Avatar
Fol. OPTIMIZED DIY 2-Bay Bowtie with Rectangular Loop performs well in BOTH UHF and Hi-VHF, running circles around any Commercial Flat Panel or Rabbit-Ears Antennas. Can be hidden behind a Picture on the Wall...but if using a METAL Frame, it should be very close to size determined by the Optimizer:
http://imageevent.com/holl_ands/mult...rectloopnorefl
Thanks for the insight. I'm going to give one of the flat non-amplified models a go. A buddy is giving me one since it didn't work for him because he lives far away from the towers. I'm trying to make cable cutting as wife friendly as possible so something that is small, hidden, and doesn't have to be adjusted is perfect.
Skeletor is offline
Reply HDTV Technical
Rca Ant1650r Flat Digital Amplified Indoor Tv Antenna
