Mitsubishi TV Resets Input During Channel Changes - AVS Forum | Home Theater Discussions And Reviews
Old 09-15-2013, 05:21 PM - Thread Starter
radracer84's Avatar
Mitsubishi TV 82'' screen turns black and flashes the input in the upper left corner when changing cable channels. HDMI 1.4a connection from Cox Cable box into a Denon 3313 CI and then an HDMI 1.4a to the TV The TV acts as if it was changing the input on every channel change. Duration is approximately 5 seconds plus the time the it take for the cable box to do its digital change.
What the heck is causing this? How do I fix it?
radracer84 is offline
Old 09-16-2013, 06:50 AM
Ratman's Avatar
Quoted: 1290 Post(s)
Liked: 1030
Try setting the cable box video setting (and Denon?) to a fixed video output resolution (I.E. 1080i)
Ratman is offline
Old 09-17-2013, 02:01 PM - Thread Starter
radracer84's Avatar
I will give it a try shortly. This is for my father's tv so I will have to run over there to mess with it. Thank you for the advice. I will let you know if it works.
