Solution to getting analog channels on my HDTV w/ a broken aux ant jack?? - AVS Forum | Home Theater Discussions And Reviews
Old 09-18-2013, 10:03 AM - Thread Starter
mikeleb86's Avatar
So after putting my 42" plasma on the wall, I ripped the aux antenna jack right out of the back of the tv by mistake. This wouldn't be an issue to me if I had cable but I currently don't and am against paying for cable. I've been happy for months picking up a dozen channels with my leaf antenna. I tried replacing the antenna jack by soldering another piece in but that was a complete failure. My next step would be to buy a new main board for the tv to replace but I can't find anything cheaper then 100$. Is there anyway around this? Maybe a digital tv tuner converter box??
With my current leaf antenna setup like I said I pick up 12 channels, all analog, 0 digital. So my concern here is to get my analog channels back.
Any suggestions??
Thanks in advance!!
mikeleb86 is offline
Old 09-18-2013, 10:14 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
I don't know how to fix that. But you can stream from the internet, either with the screen connected to you computer or direct if the screen has a wifi connection.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
Old 09-18-2013, 10:22 AM
mikepier's Avatar
Quoted: 16 Post(s)
Did you try soldering a "tail" piece of RG 6 to the board, then use an f-fitting with a coupler on the other end?
Might be easier to solder on a piece of wire rather than trying to solder back the connector.
Also how are you getting analog channels? Unless you live in a rural area with low power transmitters, mostly all channels broadcasted are digital.
mikepier is offline
Old 09-18-2013, 10:30 AM - Thread Starter
mikeleb86's Avatar
Ya, I tried soldering in wire before connecting the jack.. to tight of a spot to solder
My channel scan came back with only analog and 0 digital. I'm not in a rural area so I was kind of shocked myself to not pick up any digital channels. Maybe I need to move around the leaf.
Old 09-18-2013, 10:32 AM - Thread Starter
mikeleb86's Avatar
And to get a better idea of what I tried soldering, it was the ant jack into this piece http://www.amazon.com/gp/product/B003EG88ME/ref=olp_product_details?ie=UTF8&me=&seller=
I didn't need to solder to the board. I guess I could buy that piece (link above) but since I failed the first time soldering, im hesitant about trying to solder more parts.
Old 09-19-2013, 08:44 AM - Thread Starter
mikeleb86's Avatar
anyone? i guess replacing that piece is my only option???
Old 09-19-2013, 10:57 AM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
By far the cheapest HD tuner you'll find is THIS which has the added advantage of it being a DVR if you attach a USB HDD.
It's kind of quirky and I don't like the remote(although a new remote is being shipped now, so make sure you get new stock). Any other new HD tuner is bound to cost $100s.
Note this tuner is digital only(I can't believe if you live in the US you'd have anything but digital channels available) if all you want is analog then any old VCR with a tuner and composite output should work for you. What is your location? city.
jjeff is offline
Old 09-19-2013, 11:12 AM - Thread Starter
mikeleb86's Avatar
thanks for the reply. I actually looked into this tuner before, but decided against it since it only picks up digital channels.
Area code 06010
Old 09-19-2013, 11:29 AM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1733
Area code 06010
What analog stations were you getting?
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Old 09-19-2013, 11:37 AM - Thread Starter
mikeleb86's Avatar
nbc, fox, this tv, cozi tv, cbs, cw.. 10 channels all analog
Old 09-19-2013, 11:39 AM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1733
None of those affiliates are broadcasting in analog in your area. They're all digital. You'll need a digital tuner to get them over-the-air.
DrDon is offline
Old 09-19-2013, 11:48 AM - Thread Starter
mikeleb86's Avatar
Thought it was weird myself when doing a channel scan on both tvs after hooking up the leaf antenna i got "10 channels: annalog, 0 digital"
am I doing something wrong?
Old 09-19-2013, 12:02 PM - Thread Starter
mikeleb86's Avatar
a "digital converter" box wont work correct? these convert from digital to analog
Old 09-19-2013, 12:05 PM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1733
You can't pick up any analog channels because there aren't any. Well, there's one and it's Spanish.
So, I'm assuming you were picking up digital stations, because the channels you list include some channels that are digital subchannels.
You're probably going to have to find someone who's good with a solder gun to attach a new F-connector to the tv board. Of course, if you have to pay for that, then you might as well buy a new board or a set-top box. Were it me, I'd just go with some of the suggestions above. And probably a rooftop antenna. Those "leaf" antennas are largely expensive gimmicks.
DrDon is offline
Old 09-19-2013, 12:31 PM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1733
I'm sure your plasma has a composite video (yellow jack) input, but why would you want to put a standard-definition picture on a plasma. No, you need a converter with a component or HDMI output. You can run through our list here: http://www.avsforum.com/t/179095/the-official-avs-hdtv-stb-synopsis But you'll need to research those out. Hasn't been updated in a while and some of those are out of production. Though there is always someone willing to sell one.
DrDon is offline
Old 09-19-2013, 12:32 PM - Thread Starter
mikeleb86's Avatar
No, i've said this whole time that ive been picking up only analog channels (from what both of my tv tuners have told me) and 0 digital channels
Old 09-19-2013, 12:36 PM - Thread Starter
mikeleb86's Avatar
so a converter box will kill the quality since it changes it over to analog correct?
I understand I need a composite or hdmi to tv out
Old 09-19-2013, 01:08 PM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1733
You're confusing broadcast methods with picture signals. Analog television broadcasting ceased a number of years ago. Analog US broadcasts were limited to standard-definition picture signals. Digital broadcasts can carry HD picture signals. At your end of things, the digital broadcast is converted to something your television can display. On a set top box, composite outputs (yellow) can only carry standard definition analog picture signals. Component outputs (red, green, blue) carry high-definition analog picture signals. HDMI carries digital signals to the television and lets IT do the conversion. So, anything with HDMI or component outputs will give you HDTV.
You don't have your coax still hooked into the cable system, do you? Cable companies still send some analog channels. Usually, local broadcast and community access. If that's what you're doing, but not paying for it, then it's theft of service.
DrDon is offline
Old 09-19-2013, 01:27 PM - Thread Starter
mikeleb86's Avatar
I have picked up a couple HD channels so I must be picking up digital.
I'm not hooked up to any cable system
Old 09-20-2013, 08:17 AM - Thread Starter
mikeleb86's Avatar
Alright since I've come to the conclusion that my channels coming in are in fact DIGITAL... and not analog like i thought. I ordered the iView 3500STB DTV Converter Box that was recommended above as well as the replacement tuner piece to solder in when I get around to it.
I will share my results next week when I first try the converter box..
also, I moved the antenna yesterday and rescanned my channels getting a total of 16 now!!.. kinda curious to see if hooking up the tuner will increase my antennas range
Old 09-20-2013, 06:05 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
I hope your OK with the iView. Like I said the original remote(which they may still be shipping) really lacked. It was small and illogically laid out(like a Cyberhome DVD remote if your familiar with that) and the tuner is a bit quirky(mostly related to the DVR function). Overall for the price I find it a bargain, but it ain't no Tivo biggrin.gif
jjeff is offline
Old 09-25-2013, 12:49 PM - Thread Starter
mikeleb86's Avatar
This device did the trick! Picked up all my 16 channels im currently getting. Will definitely consider upgrading the remote. Thanks for the advice!
