Salisbury, MD: Looking for new Antenna to go on top of existing 30ft Tower - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-18-2013, 01:00 PM - Thread Starter
M1chael's Avatar
Quoted: 12 Post(s)
All-
I am trying to assist a grandparent with cutting the cord to cable (the cost is getting to much for them) and they have an existing antenna tower but would need a new antenna (HD).
Can anyone provide some good suggestions for antenna brands / models / etc? (i.e. ChannelMaster)
Also, I put the address in TVFool in case that helps with reception questions...
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d46aec1e6e72810
Thanks in advance for any assistance you can provide.
M1chael is offline
post #2 of 2 Old 09-18-2013, 01:46 PM
tylerSC's Avatar
Quoted: 797 Post(s)
Liked: 180
Your nearby Salisbury, MD stations are about 40 miles and UHF for the major networks. A 4-bay or 8-bay UHF antenna could work there, and possible medium gain preamp. But if you want Baltimore or Philadelphia, it becomes a bit more involved. Some are VHF and more distant. Perhaps a 91XG UHF antenna and a separate VHF antenna. And DC and New York may be a bit beyond range, but I would definitely try for Baltimore.
tylerSC is offline
Reply HDTV Technical
