Finding good ground on the roof of a new home - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-28-2013, 12:03 PM - Thread Starter
josephforum's Avatar
Hi All,
I just purchased and RCA ANT751 outdoor antenna.  I am trying to find a good ground on the roof but seem to be stuck.
To start of, my backyard is 80% cemented so can't drive any rods into the ground.  The only metal I see on the roof is a metal pipe that allows the power lines to come into the home. Could this metal pipe be a good ground?
Other metals are vents from the water heater.
If none of the above I mentioned are good for ground then where can connect to ground?
Thanks in advance,
Joseph
josephforum is offline
post #2 of 5 Old 09-28-2013, 02:41 PM
ProjectSHO89's Avatar
Quoted: 206 Post(s)
Liked: 109
How old is the building?
Where is the electric service meter? The meter base is always grounded and you should be able to access the the GES there or very close by.
ProjectSHO89 is offline
post #3 of 5 Old 09-28-2013, 03:40 PM
Colm's Avatar
Liked: 94
NEC allows bonding to the metallic power service raceway (the metal pipe the power lines in in through). Use an approved grounding clamp.
Colm is offline
post #4 of 5 Old 09-28-2013, 04:48 PM - Thread Starter
@ProjectSHO89:Thanks for the reply. The home was built in 2005.  I have a two story home. The electric meter is on the south side of the home close to the first floor. This would be about 40 ft away.
thanks,
Joseph
post #5 of 5 Old 09-28-2013, 06:45 PM
Quoted: 206 Post(s)
Liked: 109
Okay the IBT wasn't required until the 2008 code cycle, so an 05 construction probably doesn't have it.
Yes, if the power mast is metal, then it is one of the approved connections.
Reply HDTV Technical
