Directv slimline connected to zinwell WB616 at townhouse - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-28-2013, 06:50 PM - Thread Starter
heydewd's Avatar
My townhouse complex has what looks like a Directv Slimline ka/ku dish on the roof. It feeds a Zinwell WB616 with 4 coax leads feeding it. I brought home an HR22-100 receiver from work (8 miles away) and tried to connect it to the RG6 feed to my smart panel.
The receiver says no signal.  This technology is not my forte.
My questions are:
1) will this receiver work with this system?
If so, what do I set the dish type to?  swm or multiswitch  and what dish type
2) will i need a b band converter?
Thanks in advance..
Mike
heydewd is offline
post #2 of 7 Old 09-29-2013, 08:24 AM
RoyGBiv's Avatar
Quoted: 75 Post(s)
Liked: 35
An HR22 will work with this setup. You will need to connect both inputs on the HR22 to the satellite in order to be able to record 2 programs or record one and watch another. The antenna type would be multiswitch, not SWM, but the receivers are pretty good at setting the antenna type correctly, and you would need B Band converters for both coax inputs.
SMK
RoyGBiv is offline
post #3 of 7 Old 09-29-2013, 08:16 PM - Thread Starter
heydewd's Avatar
SMK,
Thank you for the response.  The receiver is not seeing a signal. I have hit the reset button hoping it would auto detect.  It get a 775 error.  Does the smart store this info?  The  HR22 receiver is from my office, about a year ago it went from Multiswitch to SWM with the inline power inverter when they installed a new dish.
My townhouse runs that Zinwell switch.  I wonder if the dish got moved on the roof.  I tired to manually look for transponders and it see nothing.
heydewd is offline
post #4 of 7 Old 09-30-2013, 07:37 PM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
Originally Posted by heydewd View Post
SMK,
No, the problem is your receiver is looking for the SWM dish.
Connect the receiver to the WB616, using two BBCs. Go into satellite setup. Select "multiswitch". Then select the correct dish type. Now the receiver will be ready to go through alignment.
texasbrit is offline
post #5 of 7 Old 09-30-2013, 09:59 PM - Thread Starter
heydewd's Avatar
One last dumb question.  Does the received need the BBC's to even see the signal?
heydewd is offline
post #6 of 7 Old 10-01-2013, 06:56 AM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
Without the BBCs, you won't see some of the HD satellite signals. You will get the 101 signals though, so you can do the initial stages of alignment. If you need BBCs, just call DirecTv and they will send you some free of charge.
post #7 of 7 Old 10-01-2013, 12:38 PM - Thread Starter
heydewd's Avatar
Thanks... The dish must be not alligned properly then.  I get no signal at all.  Thanks for all the help.
heydewd is offline
Reply HDTV Technical
