How to eliminate 'hum'? - AVS Forum | Home Theater Discussions And Reviews
Old 09-29-2013, 03:41 PM - Thread Starter
markg2's Avatar
HDTV connected to DirecTV genie box with HDMI. 2 Logitech speakers connected to the headphone jack.
There's a constant volume sensitive hum emitting from the speakers. I've switched the speakers with those in a similar hookup on another TV yielding the same hum--it's not the speakers.
Is there not a way to filter/eliminate the hum?
Mark
markg2 is offline
Old 09-29-2013, 04:35 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
You may need a coaxial ground loop isolator to eliminate the hum. Check Viewsonics brand on Amazon, or generic version from MCM Electronics.
tylerSC is offline
Old 09-29-2013, 04:43 PM - Thread Starter
markg2's Avatar
There's coax from the remote Genie server to the wall jack, coax from the wall jack to the slave then HDMI from the slave to the TV.
So the isolator (I ordered the Viewsonic) simply screws either between the wall jack and coax cable to the slave or between the coax cable and the slave--doesn't matter at what end of the existing short coax cable?
Mark
markg2 is offline
