Help picking an antenna Mobile AL - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-02-2013, 10:22 AM - Thread Starter
squirreltactic's Avatar
TV Fool results: http://imgur.com/a/5yhGm
I have  a directional external antenna, but it was a pretty cheap one.  Got it on special from some overseas website, no brand type thing.  All said, it has served me well.  It seems like it's broken or something, as it isn't picking up VHF anymore.  It fell off the roof a while back and I just put it up after I cut cable television again.  I'm looking to buy a new antenna.  Although on my TV Fool results WALA (fox) shows green, when I downloaded the GoogleEarth plugin they have it showed that station yellow for me.
I was just wondering whether I would be served better from a roof antenna or could I get by with a good attic one?  Do you get more protection from lightning when using an attic antenna?  If I were to get a high powered external one could I maybe get some of tose channels far west of me or far southeast or is that not very likely?  I don't mind spending a little money on a nice one (and I can mount it pretty high), I just don't want to bother if I won't get much advantage over a lower one.  Any suggestions on models that would suit my needs?
Thank you.
squirreltactic is offline
post #2 of 6 Old 10-03-2013, 04:21 PM
Super Moderator
DrDon's Avatar
Quoted: 1019 Post(s)
Liked: 2038
Rooftop is almost always better. Attics are multipath nightmares and different construction materials can attenuate the signal. That's not to say it won't work. It can simply be a trial-and-error nightmare to find the sweet spot. Or you could get lucky and everything works. Rooftop alleviates those issues and, with the addition of a pre-amp and a rotor, may allow you to pull in signals you most certainly would not get with an attic mount. You'll need a UHF/VHF-Hi combo. Avoid the gimmicky antennas and stick with old school.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #3 of 6 Old 10-03-2013, 08:26 PM - Thread Starter
post #4 of 6 Old 10-04-2013, 03:54 AM
ProjectSHO89's Avatar
Quoted: 261 Post(s)
Liked: 129
CM 3020 - Heck no
CM4228 - okay but overkill
RCA751 - good fit
Also suggested: Antennacraft HBU-22, Winegard 7694, Antennas Direct C2V, ChannelMaster CM2016
squirreltactic likes this.
ProjectSHO89 is offline
post #5 of 6 Old 10-08-2013, 05:04 PM - Thread Starter
I was told that one like the CM4228 will work bi-directionally to some extent and since my stations are essentially 180 degrees apart i may be able to kill all the birds with one stone (with the channels on the back end maybe not being quite as strong).  Is this bogus info or is there something to this?
post #6 of 6 Old 10-08-2013, 05:07 PM - Thread Starter
Sorry if this is a pointless reply.  I may have clicked on the wrong reply button when I posted the above comment.  I was specifically trying to reply to your post, but i think I did a general thread reply.
Reply HDTV Technical
