Ashland, OR: Need help getting KDRV on Antenna - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-08-2013, 09:12 PM - Thread Starter
lewi1913's Avatar
Hey guys, today I took the plunge and bought a Clearview 2V antenna for our TV. Budget is tight since I lost my job recently, and cable was out of the question.
Antenna works great, except that I cannot get ABC (12) to come in, which is the channel I wanted most (for NBA coverage).
Looking for some help, if an amplifier would help me at all. I was looking at the PCT unit.
The TV Fool report says I should get ABC, but I can't get any signal. I haven't tried taking the antenna outside yet, its in the living room of our aparment now, facing west. Most towers are to the north, but I tried each direction in the house, this was the best signal.
My apartment will not let me mount this anywhere on the building, but I may be able to make an outdoor pole or something in our back yard if I could get ABC.
I realize the tower is 42 miles away, but so is the NBC tower, and that one comes in fine.
I am running a new Samsung smart HDTV, by the way.
Any help is appreciated, here are my antenna reports:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d46ae7cbcb53831
http://www.antennaweb.org/Stations.aspx?Address=Rock+Street&City=Ashland&State=OR&ZIP=97520&Housing=S&Accuracy=5&Height=6&Obstructed=False&StationList=&Lat=42.2054723&Lon=-122.7220975
lewi1913 is offline
post #2 of 6 Old 10-09-2013, 04:03 AM
ProjectSHO89's Avatar
Quoted: 211 Post(s)
Liked: 110
Did you get the ClearStream 2 or the 2V?
ProjectSHO89 is online now
post #3 of 6 Old 10-09-2013, 06:30 AM - Thread Starter
lewi1913's Avatar
Sorry, I got the 2V
lewi1913 is offline
post #4 of 6 Old 10-09-2013, 06:41 AM
Quoted: 211 Post(s)
Liked: 110
Take the antenna outside. Trying to get VHF indoors from 42 miles away is a crap shoot. Your odds are probably better at a craps table. Experiment with multiple locations. Try an FM filter, Radio Shack 15-0024, about $5. Do NOT use an amplifier unless you get one with a very high input overload tolerance.
post #5 of 6 Old 10-09-2013, 08:27 AM
Super Moderator
DrDon's Avatar
Quoted: 876 Post(s)
Liked: 1734
Please add a location to all antenna help threads. See my edit and the sticky threads at the top of this section.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #6 of 6 Old 10-09-2013, 10:08 AM
Mister B's Avatar
Quoted: 17 Post(s)
According to Wikipedia, K21BG transmitting on channel 21 is a translator or your ABC affiliate. With line of sight at only 6.5 miles it should be available. I would check again to see if you are getting any signal on 21 and move the antenna to optimize the read-out on your signal quality meter. Just in case you re not aware, all of those channels with numbers in the call sign are translators.
Mister B is offline
Reply HDTV Technical
