UHF signal reception clearer during rain - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-10-2013, 01:50 AM - Thread Starter
qwerty99's Avatar
My TV antenna received very signicantly stronger UHF signal during rains. This is the exact opposite of what is usually the norm. Can anyone give me any reasons why it's so? Is it because my antenna has some wires in it becoming rusty and hence loses contact during normal days, while the rain water establishes back the connection. I have rather poor reception on non-rain days from that UHF channel.
qwerty99 is offline
post #2 of 8 Old 10-10-2013, 04:16 AM
tylerSC's Avatar
Quoted: 722 Post(s)
Liked: 166
Depends on clouds and weather conditions. Sometimes rainy days I get better UHF signals; other times reception is worse.
tylerSC is offline
post #3 of 8 Old 10-10-2013, 07:09 AM - Thread Starter
qwerty99's Avatar
For mine, the rainy days always bring great reception, i did not see any occasion where it rains and the UHF channel getting worse. So it's the clouds or something that helps the signal, seems more like it, compared to my theory about the water connecting loose parts..you think?
qwerty99 is offline
post #4 of 8 Old 10-10-2013, 07:36 AM
Super Moderator
DrDon's Avatar
Quoted: 877 Post(s)
Liked: 1734
Could be a number of reasons. You didn't include a location or a TV Fool report, so anything we tell you is just speculation.
Could be that the storm is attenuating interference.. multipath or a distant station. Weather fronts play havoc with signals in a number of ways and on different bands. Ask anyone near you with a ham license.
Also note that, unless you're using an actual spectrum analyzer, your signal meter is probably just giving you an inverse error-correction reading. Most of the "signal meters" in digital televisions give a reading based on error correction and not actual signal strength. Therefore, removing interference would make your reading go from, say, 60% to 80%.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #5 of 8 Old 10-10-2013, 08:10 AM - Thread Starter
qwerty99's Avatar
Not sure where the usual location the users here are at, but I'm not in the States or any Western countries. I actually live on a slightly more elevated area, sort of a hilltop in an urban area. Our place here don't have HDTV yet. So my UHF and VHF antenna combo is for what I believe is analogue transmission on terrestrial TV.
qwerty99 is offline
post #6 of 8 Old 10-10-2013, 09:52 AM
Otto Pylot's Avatar
Quoted: 1363 Post(s)
Liked: 854
I think this is where OTA reception gets frustrating for some because there sometimes just doesn't seem to be any rhyme or reason why some folks have issues and others don't. For us, we live 50 miles or so from the towers (excellent LOS) and weather has no effect on our reception at all. It can be very stormy and rainy, windy, or 105 F outside and our reception never wavers, and our roof-mounted antenna is almost 30 years old! 5 or 10 miles to the East or West of us, and folks have weather-related issues.
Otto Pylot is online now
post #7 of 8 Old 10-10-2013, 01:35 PM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
When I was young living in Garland, Texas I used to mess with TV Dxing or receiving VHF-TV signals from far away. I found if the signals tends to fade some then clear up then fade again, the antenna needs to be higher.
When it rains the TV signal is increased nearer the ground. Think of the rain as a large rather flat metal bowl turned upside down holding the TV signal closer to the ground. This is a sign you may need a higher gain antenna or adding a preamp near the antenna may also help.
If you using a outdoor antenna using 50 foot or more of coax you can add a preamp at the antenna and overcome the signal loss in the coax to increase your picture quality.
I'm assuming your using a outdoor antenna and not a indoor amplified one.
WhiteSands is offline
post #8 of 8 Old 10-10-2013, 06:24 PM
Otto Pylot's Avatar
Liked: 854
Our antenna is 30' from ground level, sitting on top of about a 12' mast at the apex of our roof, on a single story home. The roof is metal, the RG-6 coax run is about 90'. No pre-amp at the antenna and only a signal booster in the garage where the coax comes in, gets split to 2 tv's, and then goes on to the house via the builder installed RG-56 coax.
Reply HDTV Technical
