Vera wifi - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-16-2013, 06:54 AM - Thread Starter
Tolmst's Avatar
Got a Panasonic Viera with a Panasonic wireless adapter connected to the USB. I manually entered the IP address, subnet and gateway into tv's setup. Now when it performs connection test everything is ok until it checks connection to the Internet. In network setup it has found the wireless router. What else should I check?
Tom
Tolmst is offline
post #2 of 5 Old 10-16-2013, 08:25 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1028
DNS server(s) address?
Why not just use DHCP?
Ratman is online now
post #3 of 5 Old 10-16-2013, 09:38 AM - Thread Starter
Tolmst's Avatar
I believe it was dhcp but then couldn't acquire the IP address. I will verify tonight. It did work that way for 6 months. Then my son got into the router to check something. Maybe he changed something??
I tried all 3 of the DNA servers listed in router setup. Still didn't work.
Tolmst is offline
post #4 of 5 Old 10-16-2013, 12:36 PM
Ratman's Avatar
Liked: 1028
Sounds like he did. If it worked before using DHCP, it should work now.
post #5 of 5 Old 10-16-2013, 11:18 PM
holl_ands's Avatar
Quoted: 440 Post(s)
Liked: 182
You should get you son to Reset the Router to the DEFAULT settings,,,,make sure the Viera's Wi-Fi works OK....and then make incremental, small changes to Router, checking to make sure that Viera can still Search and Find the connection...until one of those incremental changes causes it to quit.....and then undo that incremental change until he has an AH-HA moment and finally gets it right....
holl_ands is offline
Reply HDTV Technical
