HDMI to cable coaxial - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-18-2013, 08:02 AM - Thread Starter
cbdeajr's Avatar
I have an older motor home in which I have upgraded the TVs and would like to be able to connect the DVR and cable box to the coaxial cable that runs to the rear TV. It would be a major job to run a new HDMI cable to the back. I have a splitter on the coax coming to the cable box and get some channel on the rear TV but the DVR only has HDMI output. I do not care if I get all the channels in the back but would like to get the DVR signal. Is there a converter or something I can use?
cbdeajr is offline
post #2 of 7 Old 10-18-2013, 08:33 AM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
What kind of DVR/Cable box do you have?
I've seen many that had a coax output and you were able to use both the HDMI for the local TV and the RF/COAX for the remote TV.
walterappleby is offline
post #3 of 7 Old 10-18-2013, 08:37 AM
Kal Rubinson's Avatar
Quoted: 677 Post(s)
Liked: 460
i have not tried any but I believe there are HDMI-over-coax adapter kits that will get the signal over your installed cable.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #4 of 7 Old 10-18-2013, 04:15 PM - Thread Starter
cbdeajr's Avatar
Both the DVD and cable box have only  HDMI connectors
cbdeajr is offline
post #5 of 7 Old 10-18-2013, 09:41 PM
Quoted: 677 Post(s)
Liked: 460
Right.  And the TV?
Kal Rubinson
post #6 of 7 Old 10-19-2013, 05:26 PM - Thread Starter
cbdeajr's Avatar
Tv's have rca and HDMI
cbdeajr is offline
post #7 of 7 Old 10-19-2013, 10:20 PM
Quoted: 677 Post(s)
Liked: 460
Right.  One part of the HDMI-over-coax kit takes your HDMI source signals and sends them over coax.  At the other end of your installed coax, the other part of the kit reconverts the signals to HDMI to feed your TV.
Kal Rubinson
Reply HDTV Technical
