help hooking up 2nd TV to Onkyo receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-28-2013, 11:32 AM - Thread Starter
Nick0814's Avatar
here's what I've got - my Onkyo TX-NR818 has a 2nd HDMI output I want to use on the TV in my kitchen. Previously it was hooked up right to the Directv box via coax cable which is still there. Is there any kind of adapter that would take the HDMI output of the Onkyo and convert it to the coax that is ran to my kitchen and either stay cox or turn back into HDMI to put the signal on that TV?
Nick0814 is offline
post #2 of 7 Old 10-28-2013, 01:18 PM
Ratman's Avatar
Quoted: 1288 Post(s)
Liked: 1028
Ratman is online now
post #3 of 7 Old 10-28-2013, 02:30 PM - Thread Starter
Nick0814's Avatar
Nick0814 is offline
post #4 of 7 Old 10-28-2013, 02:43 PM
Ratman's Avatar
Liked: 1028
post #5 of 7 Old 10-28-2013, 02:56 PM - Thread Starter
Nick0814's Avatar
well do you know if my Onkyo has a way to send a signal to the 2nd TV without using the HDMI?
Nick0814 is offline
post #6 of 7 Old 10-28-2013, 03:30 PM
Ratman's Avatar
Liked: 1028
If the Onkyo has a composite video output, you can use that over coax. But.... it will be video only and limited to 480i resolution. No audio either.
EDIT:
You may consider wireless:
http://www.amazon.com/Nyrius-Transmitter-Streaming-Satellite-NPCS549/dp/B009E6R89C
http://www.bestbuy.com/site/iogear-wireless-3d-a-v-transmitter-and-receiver/4844721.p?id=1218542466682&skuId=4844721
post #7 of 7 Old 10-29-2013, 08:18 AM
Beerstalker's Avatar
Liked: 24
You could use the composite video out, and one of the audio outs and go into an RF modulator. Then hook the RF modulator up to the coax run that goes to the kitchen.
This will only be standard def, and the coax line to the kitchen has to be direct, it can't go through any splitters or be hooked into the DirecTV wiring anymore.
Beerstalker is offline
Reply HDTV Technical
Onkyo Tx Nr818
