Volume Control on TV's Audio Out Ports - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-07-2013, 02:01 PM - Thread Starter
ascharch's Avatar
I just got a pair of KRK Rokit 8 powered speakers. I'm pleased, all is well, but I'd like to hook up my future TV to play audio through them. I'm planning on either getting a Panasonic TC-LE60 series or a Samsung UNF6350AF.
The Panasonic offers only digital audio out via Toslink. I assume a DAC would work fine to convert the signal, but I would imagine that the TV only outputs a constant volume to that port which can't be changed by remote or any other means.
As for the Samsung, it offers the same plus an audio out via minijack. Seems like it would be fine, but I want to make sure that I'll still be able to control the output volume with the remote, since it's not labeled as a headphone jack.
So, to wrap things up, my questions are as follows:
1) Is it possible (and if so, likely?) that a TV would let the user vary the volume on a digital audio out port?
2) Is there a way I can find out if the Samsung will let me do the same for the minijack audio out?
3) Is there any reason digital or analog outs would offer better quality over the other?
Thanks in advance for any responses!
ascharch is offline
post #2 of 2 Old 11-07-2013, 08:47 PM
holl_ands's Avatar
Quoted: 564 Post(s)
Liked: 248
IF the Toslink Digital Audio (Optical) Output is capable of Variable as well as Fixed (normal for connection to AVR), then there will have to be a Fixed/Variable Setting in the HDTV's Audio Settings Menu. A simple check of each User's Guide should answer your question with certainty. [Download from manufacturer's website.]
ascharch likes this.
holl_ands is offline
Reply HDTV Technical
