Novi, MI Reception Issues and set up help! - AVS Forum | Home Theater Discussions And Reviews
Old 11-16-2013, 08:04 PM - Thread Starter
Cinemafreak1's Avatar
Hello,
New to OTA HD signals and just moved to the area.  I just bought a RCA ANT751 which I just installed in my attic.  Pointed it towards the 90-105 degree direction.  Here are my TV Fool results, http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d46ae1e4bf2f377
Here are my issues:
I had to run 40 Ft of RG6 which is coupled to the run from my Master Bedroom to a spliter that sends the signal to the TVs ion 3 other rooms.
I ran my tv auto signal search and got 2.1, 2.2, 4.1, 4.2, 7.1, 7.2, 7.3, 9.1, 20.1, 20.2, 50.1, 56.1, 56.2, 56.3.  All are 87% plus signal strength.
The Channels I am missing are 48.1, 38.1 and 62.1 which is CBS and the one I want the most.
I also have a Mohu Leaf which is connected directly to a TV on the first floor.  I not only get the channels I already get with the ANT751, but the ones that I am missing and more.
What is my issue here?  Too long of a run for a passive splitter?  The coupling at the Master Bedroom point?  Do I need a Channel Master 3414 4 Outputs Distribution Amplifier to replace the passive one that came with the house?
Please Help!
Cinemafreak1 is offline
Old 11-17-2013, 05:04 AM
ProjectSHO89's Avatar
Quoted: 212 Post(s)
Liked: 111
Move the antenna and try again. As little as 6-12" can make a difference, especially when the antenna does not have clear line of sight.
Don't know. You will need to do some some single cable test with a temporary cable each set to see if the problem is the signal off the antenna or if it's the distribution cabling.
Probably not. Your signals in your area are calculated to be strong enough to push several hundred feet of cable plus splitters unless, of course the antenna is in a dead spot for certain channels. Happens all the time in attics and its far more severe if you have trees in front of the antenna.
ProjectSHO89 is offline
Old 11-17-2013, 09:08 AM - Thread Starter
Well, the issue with moving the Antenna is how bad the attic is set up.  There is no easy way to move and mount it in another place.  There are no cat walks.  Maybe I need a pro, but what will that cost?
An update, I linked the other TV that had the Mohu to the attic antenna and I get 62.1, but with a little stuttering.  I am confused, how can one TV get the signal and the other does not?  Doesn't that tell me that the antenna is getting the signal, but is losing it along the way to the other TV?
Plus I get all the other signals at full strength.
Other than moving the antenna are there other options?
Old 11-17-2013, 09:23 AM
Quoted: 212 Post(s)
Liked: 111
You can make excuses or progress, if you want, but I've already given you the directions to a solution.
You have an antenna that is matched to your location, now all you need to do is put the antenna where IT needs to be. There is no Band-Aid or magic pixie dust that will patch a broken location.
Old 11-18-2013, 10:58 PM
deltaguy's Avatar
Quoted: 17 Post(s)
I'd try the Leaf on each of your televisions. That would certainly eliminate the long cable run.
deltaguy is offline
Old 11-19-2013, 04:11 AM
Super Moderator
DrDon's Avatar
Quoted: 881 Post(s)
Liked: 1740
Tuners are different from TV to TV. Not surprising one can display a marginal signal when another one cannot.
Attics are multipath nightmares. Finding the sweet spot - if there is one - can take forever. Depending on the materials used in your roof or siding, air conditioning equipment and romex running through the attic.. interference can be extreme. I'm not far from you and I can get Toledo with a small yagi from an upstairs bedroom ..but not at all from the attic. I had to go to the roof to get around my neighbor's house, which was causing enough reflection to make using rabbit ears or an attic antenna useless.
If you need to, get some heavy-duty plywood cut into strips to make your own catwalk. Better still, head for the roof.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Old 01-23-2014, 05:09 PM
meltedsteam's Avatar
The long run will most certainly degrade your signal especially if split. Location is key, but a pre-amplifier next to the antenna may solve your problem.
meltedsteam is offline
Old 01-24-2014, 08:10 AM - Thread Starter
Update:
Found the two main issues, cable run and split. I hooked old 14 inch tv direct to antenna and all good. So I shortened the run, added an amp and used a 3 way splitter instead of the 5 that come with the house. All good....30 channels!
