HDMI over Cat5 converter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-18-2013, 11:03 AM - Thread Starter
patmac57's Avatar
I have a LG tv. 47lv5400. I have Vanco cat5 to HDMI converters. 70 to 80 ft. in length. I am running a DTV receiver HR24 out to a Pioneer 523 surround sound. The way it is run is sat rx out to HDMI in on ss rx. HDMI out to cat5 converter. At tv which is 70 to 80 ft away I have the rx end of the cat5 converter. At this point I go cat5 converter HDMI out to tv. I am just transmitting video here. It works ok until the tv is turned off. When I go to turn tv back on the image is there but the screen is purple. I can turn off ss and back on and it clears up or I can switch inputs on ss. (ex: Go from TV/SAT input to DVD and back) Either on of these functions will clear up tv until tv is turned off again. I replaced the cat5 converters first with no success then I replaced the Pioneer ss and it worked for awhile but now it is doing it again. Is this a handshake issue? This is a customer of ours and they are rapidly becoming impatient. Please, does anyone have any suggestions? Oh and I replaced the tv as well with no luck.
patmac57 is offline
post #2 of 5 Old 11-18-2013, 01:56 PM
Ratman's Avatar
Quoted: 1278 Post(s)
Liked: 1027
I can understand if I hired a "professional" and they can't figure it out. Maybe you should refer the customer to this website to save them a few dollars in time and labor. smile.gif
Ratman is offline
post #3 of 5 Old 11-18-2013, 08:57 PM
reddog007's Avatar
So you replaced the TV and the converter boxes?
How long of a CAT run can those converter boxes support? When our coverter boxes have long CAT runs they can do funny things.
Have you tried shielded CAT cable? Maybe Cat6/6a could help too maybe.
reddog007 is offline
post #4 of 5 Old 11-19-2013, 04:06 PM
JBfromBrazil's Avatar
CAT 5 cables are ( UTP, unshielded transfer pair ), with a limit of 75 ft for 100 Mb transfer rate.
You can try shield the CAT to check, or ask for a good professional. He'll save your money and patience.
regards
JB
JBfromBrazil is offline
post #5 of 5 Old 11-20-2013, 07:44 AM
SAM64's Avatar
Liked: 78
regards
JB
UTP means Unshielded Twisted pair.
The limit is 100M (about 300 feet)
Cat 5 can be shielded or unshielded
SAM64 is offline
Reply HDTV Technical
Lg Infinia 47 Inch Led Lcd Hdtv With Smart Tv 47lv5400 , Pioneer Channel Av Receiver Vsx 523 K
