Yuma,AZ ota antenna help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-11-2013, 04:59 PM - Thread Starter
Quoted: 17 Post(s)
So confused on what would be the best OUTSIDE antenna for my area 85365. Any help is GREAT !
Dickie
wanab is offline
post #2 of 5 Old 12-12-2013, 09:20 AM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
bac522 is offline
post #3 of 5 Old 12-14-2013, 03:24 AM
dhett's Avatar
Quoted: 24 Post(s)
All I can tell you is that you need something that will pull in high-band VHF, as that is where the signals for English-language channels KECY 9.x (Fox/ABC/MyNet/CW), KYMA 11.x (NBC/This) and KSWT 13.x (CBS/Tuff TV) originate. All three broadcast from Black Mtn., located NNW of the city. Two other English-language stations come from Telegraph Pass, where I-8 winds through the mountains between Fortuna Foothills and Wellton. Those stations, both low-power, are a digital religious station on ch. 17.x (if it's finally up and running), and an analog KAET-8 (PBS) repeater on ch. 19. For all 5 stations, the RF channel and virtual channel are the same. You shouldn't need an amplified antenna, but you're far enough away from the towers that having an amplified antenna shouldn't overload your TV with signal.
I can give you info on the Spanish-language channels if you request them.
Dave
dhett is offline
post #4 of 5 Old 12-14-2013, 07:34 AM - Thread Starter
Quoted: 17 Post(s)
Thanks....now I know what kind to get. The one I have now was left from the previous owner of the house. No wonder she told me you need to get Directtv because her antenna was like a bow tie on the mast. Thanks again.
Dickie
wanab is offline
post #5 of 5 Old 12-15-2013, 02:17 AM
dhett's Avatar
Quoted: 24 Post(s)
You might want to keep the bowtie around and join it with whatever you buy. The main English-language stations are all VHF on Black Mtn. to the NNW, but your PBS station will be to the east of you, on UHF 19. If you orient the bowtie east/west, it should pick that one up, plus, if the antenna doesn't have a reflector, you might get all the Mexicali stations from the west as well - if Spanish-language stations are of any interest to you.
dhett is offline
Reply HDTV Technical
