Palm City, FL: Can a paper clip receive Hi-V channels? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-06-2014, 10:36 AM - Thread Starter
bszent's Avatar
My zip code is 34990 for reference of my location using http://transition.fcc.gov/mb/engineering/dtvmaps/
I am receiving all of the the VHF channels that the website above says I should get, but it says NBC is a Hi-V channel. Do I need to buy a special antenna to get NBC?
bszent is offline
post #2 of 5 Old 01-06-2014, 10:56 AM
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
That station is 40 miles from the center of your zip code, so ordinarily you would not expect to get reliable reception from a paperclip or even from a set top antenna, but if you already own a TV or tuner, then all you have to do is try it before buying a more substantial antenna.
AntAltMike is offline
post #3 of 5 Old 01-06-2014, 11:50 AM
ADTech's Avatar
Quoted: 134 Post(s)
Liked: 72
You might need a "jumbo" sized paper clip for that one.... :rolleyes.gif
Posting the link to the FCC page isn't useful as it doesn't give any of your data to anyone else. Use TVFool instead to share your signal analysis.
WPTV and WPEC are the two closest VHF channels in your general area. All other local stations, REGARDLESS of the displayed channel number, are UHF stations until you get to Miami or Orlando.
Tech support for Antennas Direct
ADTech is offline
post #4 of 5 Old 01-06-2014, 04:24 PM
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
Originally Posted by ADTech View Post
You might need a "jumbo" sized paper clip for that one.... :rolleyes.gif....
Here's the set top model: {
th?id=H.4855805351232581&pid=15.
And the OTARD compliant one:
th?id=H.4939393999175786&pid=15.1
post #5 of 5 Old 01-06-2014, 08:57 PM
holl_ands's Avatar
Quoted: 540 Post(s)
Liked: 239
All joking aside, although it is probably "adequate" for the stronger stations, a typical "unfolded paper clip" antenna probably won't receive NBC & CBS on Hi-VHF Ch12 & Ch13. You didn't SAY what kind of antenna you are using now....you should first try a cheap set of Rabbit-Ears/Loop Antenna, where the Ears are each set to about 14.5-in long for Ch12/13. And with those extremely strong nearby stations, do NOT use an Amplified Antenna, Preamp or Distribution Amplifier.
If Rabbit Ears aren't adequate, you're going to need a SERIOUS Antenna with more than a few dBi of Gain on Hi-VHF, as are summarized in the fol. response to a similar post:
http://www.avsforum.com/t/1509020/arlington-va-cant-get-ota-anything#post_24155257
holl_ands is offline
Reply HDTV Technical
