Dropping DirecTV. Looking to swap out to antenna. Need Advice. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-13-2014, 10:20 AM - Thread Starter
Novice2005's Avatar
My question and I hope this is in the correct forum, is my home is completely wired for DirecTV. I want to cut the cord and seeking advice on the following:
- Best outdoor antenna suggestions for HDTV
- Can I simply unhook the dish and swap it out with an antenna?
- What other equipment do I need?
Thanks in advance for the assistance!
Novice2005 is offline
post #2 of 9 Old 01-13-2014, 10:38 AM
mjd420nova's Avatar
You can reuse most of the outside coax but most are the doublelet and would need seperation. (removal of the entire length) Depending on your range to transmitting stations, an outside antenna would run arounf $70. for a 50-60 mile range, Coax should be new, from the 300 ohm balun on the antenna to the first entry point in to the home. Every barrel connector used is going to reduce the signal strength a bit and it will add up after two or three. Best to use one single run into the home to the primary set. I'm looking for a 30 foot mast, a 60 mile antenna ( there's no difference in HD antennas) and will feed three sets from an amplifier/split unit. The balun and all connectors outside will be wrapped with elec tape and sealed with silicone. That will outlast the antenna itself. Once inside and amplified, I'll split the FM for the AVR.
mjd420nova is offline
post #3 of 9 Old 01-13-2014, 11:10 AM
Ratman's Avatar
Quoted: 1287 Post(s)
Liked: 1028
There isn't a "best" antenna for HDTV. You should get the appropriate antenna for your location. Go to TVFool.com and get an idea. Post the results here for a recommendation.
Probable... the existing coax is probably RG6 and should be just fine. Depending on your location, the Dish antenna may not be installed at the same location where an antenna would be optimal.
As for "other equipment".... who knows? wink.gif At a minimum you'll need an antenna, maybe some splitters and TV's and/or external ATSC/OTA with tuners. And......... a ladder. smile.gif
Oops... and a mast and probably a mounting bracket. Depending on the location where the antenna will be located the mounting bracket could differ.
Ratman is offline
post #4 of 9 Old 01-13-2014, 11:48 AM
Super Moderator
DrDon's Avatar
Quoted: 875 Post(s)
Liked: 1734
Please see the sticky threads at the top of the forum. If those don't answer your questions then follow the instructions in #2.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #5 of 9 Old 01-13-2014, 04:05 PM - Thread Starter
Novice2005's Avatar
Los Angeles, all stations are within 10 miles of my location as per TVfool.
Was hoping to simply swap out the dish with an antenna. Guess that would be too simple.
post #6 of 9 Old 01-13-2014, 05:12 PM
ctdish's Avatar
Quoted: 67 Post(s)
Liked: 35
You should still post your TVFool results but you are likely in a strong signal area. Try something like this http://www.radioshack.com/product/index.jsp?productId=2103077
John
ctdish is offline
post #7 of 9 Old 01-13-2014, 07:30 PM - Thread Starter
Novice2005's Avatar
Thanks John, was looking for something that I could throw on the roof and feed 3 LED's.
post #8 of 9 Old 01-14-2014, 09:08 AM
Ratman's Avatar
Liked: 1028
Please post your TVFool results for others to evaluate and provide a reasonable recommendation.
Or... try here:
http://www.antennasdirect.com/hdtv-antenna-selector.html
Or... try this:
http://www.radioshack.com/product/index.jsp?productId=3739595
Ratman is offline
post #9 of 9 Old 01-14-2014, 11:00 AM
Super Moderator
DrDon's Avatar
Quoted: 875 Post(s)
Liked: 1734
The reason we posted the sticky asking for a location in the title and TV Fool results in the first post is to save you some time. Already lost a whole day.
DrDon is offline
Reply HDTV Technical
