Anyone make a Clear QAM tuner with Component output? - AVS Forum | Home Theater Discussions And Reviews
Old 01-20-2014, 09:36 AM - Thread Starter
sooke's Avatar
Quoted: 99 Post(s)
Liked: 69
I have a spare HDTV from 2003. I want to connect it to my cable service in the spare bedroom but it does not contain a clear QAM tuner. Rather than spend a monthly fee for another cable box, I'ld rather just buy a tuner. Amazon has a couple models for decent price.
Here is the problem, all Clear QAM tuners I can find have only HDMI output. This TV pre-dates HDMI and needs to be connected via component port. Anyone know where I can get a Clear QAM tuner with component output?
Panasonic TC-P60ZT60 plasma panel
Sony BDP-S5500 Blu-ray player
Arris DCX3600-M DVR
Yamaha RX-V650 AVR
XBox One
URC MX-780 remote control
sooke is offline
Old 01-20-2014, 09:51 AM
HDMI Guy's Avatar
Quoted: 169 Post(s)
Liked: 40
I think the channel master 7001 has component outputs. It has an ATSC and clear QAM tuner but I don't think it has a NTSC tuner if your cable company is still passing analog channels it would not work for the analog channels.
sooke likes this.
HDMI Guy is offline
Old 01-20-2014, 01:38 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
The iView 3500 and Homeworx tuner/DVR both have HD component output and with a USB HDD can record events. They are ~$40 from places like Amazon. Note the Homeworx requires a special firmware to tune QAM and both are only clear QAM(no CC) both are also kind of "iffy" in regards to QAM(neither have a analog tuner) so be aware of that.
Check out both models in their own threads in the HDTV Recorders forum on AVS:
http://www.avsforum.com/f/42/hdtv-recorders
I only use mine OTA and it seems to me lots of people have issues with QAM but most issues are probably due to the fact that the tuner gets it time from PSIP(no manual time set) and some cable systems don't send out PSIP information. If you only used it for a tuner and not DVR you probably won't have those issues.
sooke likes this.
jjeff is offline
Old 01-21-2014, 06:15 AM - Thread Starter
sooke's Avatar
Quoted: 99 Post(s)
Liked: 69
Thanks for the tips, guys. I'll check those out.
Arris DCX3600-M DVR
Yamaha RX-V650 AVR
XBox One
sooke is offline
