TV Coax Connector Broke Off…Options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-04-2014, 04:17 PM - Thread Starter
Resist's Avatar
So the Coax connector broke off the TV, this TV has component and HDMI inputs. Is there an inexpensive adapter that will go from the wall coax to the TV's HDMI? Otherwise my only other option I think would be to solder a new coax connector on the TV.
Resist is offline
post #2 of 4 Old 02-04-2014, 04:39 PM
Ratman's Avatar
Quoted: 1282 Post(s)
Liked: 1027
You are correct.
option 1: an external tuner
option 2: repair the broken connector
Option 1 options here:
http://www.avsforum.com/t/179095/the-official-avs-hdtv-stb-synopsis
Ratman is online now
post #3 of 4 Old 02-04-2014, 04:41 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Option 1. Research your TV and order the I/O board from the internet. I fixed my Sony TV for less than $80.
Option 2. If you are using the coax connector for OTA broadcasts (Antenna) you are out of luck. The tuner only works through the coax connector.
Option 3. If you are using the coax connector to tune cable channels you could get a set top box and connect that to the TV via HDMI.
Dropkick Murphy is offline
post #4 of 4 Old 02-04-2014, 05:54 PM
Super Moderator
DrDon's Avatar
Quoted: 873 Post(s)
Liked: 1734
Please search for existing threads before starting a new one. There are several here and in the Displays section on this topic.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Closed Thread HDTV Technical
