Belden Coax Cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-27-2014, 07:37 AM - Thread Starter
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Last week I bought a short coax cable from Radio Shack and began having pixelation/tiling problems so I switched back to the long coax that was supplied by Comcast. I'm want to switch to Belden Coax cables from BlueJeans and will be ordering 3 1ft runs and I'm curious whether I'll notice the difference in performance from the Comcast supplied coax? Also, will I notice a difference between the Belden 1505a (RG59) and the 1694a (RG6) at that short of a run? Also, does anyone know where I can buy a quality Right Angle coax adapter? Thanks
Blue Jeans RF Cables
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #2 of 5 Old 03-27-2014, 08:42 AM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
walterappleby is offline
post #3 of 5 Old 03-27-2014, 09:14 AM - Thread Starter
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
I normally use Monoprice HDMI cables but unsure of the coax cables since I was using something similar that was causing pixelation/tiling.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #4 of 5 Old 03-29-2014, 05:59 AM
Cableguy Greg's Avatar
Belden makes a very good coax cable. Comcast uses CommScope cable and PPC for their connectors. I suggest using a tri-shield or better coax cable.
Cableguy Greg is offline
post #5 of 5 Old 03-29-2014, 09:31 AM - Thread Starter
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Thanks... is the monoprice or blue jeans cable better than the CommScope cable provided by the cable company?
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
Reply HDTV Technical
