Why does my wife HATE my new UHF/VHF 14dB HDTV antenna?? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By mike88b
  • 3 Post By bac522
  • 1 Post By mike88b
post #1 of 20 Old 04-17-2014, 03:49 PM - Thread Starter
mike88b's Avatar
I just purchased a Stellar Labs UHF/VHF 14dB HDTV antenna for my apartment located just west of NYC. This is the FIRST time EVER that I am able to pull in WLIW-DT virtual & physical channel 21 at all times of the day. I installed the antenna in my bedroom on a tripod (since apt complexes don't allow rooftop installation), but my wife HATES it. Here is the pic:
So why does my wife HATE it so much?? Why can't she realize that the LARGER antennas get the BETTER signals?? Call me crazy, but I happen to think this antenna is a work of ART. My wife calls it an "eyesore". So what am I supposed to do?
scowl likes this.
mike88b is offline
post #2 of 20 Old 04-17-2014, 04:44 PM
bac522's Avatar
Quoted: 189 Post(s)
Liked: 106
Time to get rid of the wife!
DrDon, dattier and nyctveng like this.
bac522 is offline
post #3 of 20 Old 04-17-2014, 05:56 PM
rabbit73's Avatar
Quoted: 473 Post(s)
Liked: 198
Never forget:
"The King lives in the castle at the discretion of the Queen."
for my apartment
Don't you mean our apartment?
my bedroom
Don't you mean our bedroom?
Nice photo. I also think it is a work of art, but your wife is NOT going to change. You are asking for trouble if you force her to change.
Families that have children have members that favor PBS channels. I recall one antenna test by a friend. He set up two antennas for the family. One small antenna that didn't perform very well, and one large ugly antenna that gave them the stations they wanted. The family voted for the large antenna.
1. Find something that your wife likes on that channel so that she will tolerate the antenna to see that program. In other words, try to make her your partner in reception instead of an adversary.
2. Hide the antenna in an enclosure that is attractive to her but doesn't block any of the signal; perhaps made of fabric.
3. Switch to a flat panel reflector antenna, like a DIY 4-bay bowtie antenna with longer than normal elements to favor CH21. If properly designed, it could have almost as much gain as your Stellar Labs antenna, but would be easier to conceal in an attractive enclosure. A friend of mine bought a 4-bay bowtie antenna and left it in the cardboard box hidden from sight.
4. Mount a flat panel 4-bay bowtie antenna on the wall behind some artwork.
And never ignore the WAF, Wife Acceptance Factor.
I don't know if a preamp would help you or not, because I haven't seen your tvfool report.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #4 of 20 Old 04-17-2014, 08:37 PM - Thread Starter
mike88b's Avatar
YES, I meant OUR apartment.
NO. I meant MY bedroom. We have separate bedrooms. I can't get any sleep with someone else in the same bed. Sorry.
Nice photo. I also think it is a work of art..
Thanks for the compliment. At least someone else appreciates the same things that I do.
My wife had said, AFTER the fact, that this 14.8dB Clearstream C4 antenna would have been more acceptable. Problem is, that this ariel has NO VHF elements. Here's the pic:
Also, this Clearstream C4 ariel costs OVER $100! My 14dB Stellar Labs ariel only cost $35! So go figure.
unclehonkey likes this.
mike88b is offline
post #5 of 20 Old 04-17-2014, 10:05 PM
holl_ands's Avatar
Quoted: 528 Post(s)
Liked: 228
For UHF, 4-Bay Bowtie (per my FF4 or mclapp M4 Dimensions) can provide about same Gain as your Ugly Beast of an Antenna if you mount it about 4.5-inches in front of a suitable REFELCTOR, which can be a set of Reflector Rods or a Reflector Grid or a Solid Metal Foil Panel the same size as one of the modeled Reflector Grid (see models in below link)....you just have to figure out how to HIDE it whilst pointed in the requisite direction:
http://imageevent.com/holl_ands/multibay
Note that I also posted the HUM4, a COMBINATION Hi-VHF & UHF Antenna.....but with TWO sets of Reflectors, it might not meet your WAF.....
For VHF, the (2-bay) Hi-VHF Hourglass-Loop is a very easy to build DIY Antenna, that may be adequate for your location [presuming Rabbit-Ears are probably NOT]. If additional Gain is needed, Reflector Rods can be added (roughly 10-inches behind the Hourglass):
http://imageevent.com/holl_ands/loops/hivhfhourglassloop
Use a VHF and UHF Combiner (aka UVSJ) to combine with UHF Antenna above, available from Radio-Shack, Antennas-Direct, Pico-Macom and Hollands.
I also modeled COMBINED VHF/UHF Antennas, presuming that they were mounted INSIDE a 3x2-foot METAL Picture Frame. Azimuthal Coverage charts may be of interest to see how much ACTUAL GAIN is pointed towards your towers if you mounted it FLAT against a wall that wasn't exactly oriented in the optimal direction:
http://imageevent.com/holl_ands/loops [See item #1]
holl_ands is offline
post #6 of 20 Old 04-20-2014, 06:00 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
It's an "eyesore" !
joed32 is offline
post #7 of 20 Old 04-20-2014, 08:35 AM
unclehonkey's Avatar
Quoted: 344 Post(s)
Liked: 69
Originally Posted by joed32 View Post
It's an "eyesore" !
especially if you accidentally walk into it. You could poke an eye out smile.gif
unclehonkey is offline
post #8 of 20 Old 04-20-2014, 05:57 PM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
I think you can add the VHF dipole to the Clearstream 4 just like they did with the Clearstream 2V. Contact Antennas Direct about ordering that part.
tylerSC is offline
post #9 of 20 Old 04-21-2014, 01:13 AM - Thread Starter
mike88b's Avatar
When you guys sit back and insult my new antenna, you're really not helping the situation. It's already set up and configured, and I'm using it in conjunction with a Channel Master 4221, which is not shown in the photo, via a satellite quality 2500 MHz splitter/combiner. The new Stellar Labs antenna solidified my local channels, OK? Geez! rolleyes.gif
mike88b is offline
post #10 of 20 Old 04-21-2014, 01:32 AM - Thread Starter
mike88b's Avatar
Thanks. I was unaware of this. But my new Stellar Labs antenna is already set up and I'm really not interested in spending another $110+ bucks.
mike88b is offline
post #11 of 20 Old 04-22-2014, 04:13 AM
kenglish's Avatar
Liked: 40
Does your apartment building allow you to hang plants or lights from the ceiling?
If so, why not put 3 or 4 of those little screw-in hooks in the ceiling, and hang the antenna from some thin black strings?
That would put it up out of harms way, and not so noticeable.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #12 of 20 Old 04-23-2014, 12:28 PM
bobbyc's Avatar
Quoted: 64 Post(s)
Liked: 37
Tell her size DOES matter!
bobbyc is offline
post #13 of 20 Old 04-23-2014, 02:14 PM
HockeyoAJB's Avatar
Quoted: 975 Post(s)
Liked: 814
This could have unintended consequences...
HockeyoAJB is offline
post #14 of 20 Old 05-09-2014, 02:41 AM - Thread Starter
mike88b's Avatar
Size DOES matter, when it comes to HDTV & Satellite Antennas. As far as that "other" thing goes....
mike88b is offline
post #15 of 20 Old 05-11-2014, 01:50 PM
Maeve011's Avatar
But is it affecting y'alls sex life??
If so, try finding a way to incorporate the antenna into your bedroom activities.
BTW, she's wrong.  I'm a woman and I think your antenna is a piece of art, too.
Maeve011 is offline
post #16 of 20 Old 07-09-2014, 04:19 AM - Thread Starter
mike88b's Avatar
I'm not so sure how that would work.
Thanks. I guess some of the other people on this forum could use an eye exam. Or maybe they're just "uncultured".
mike88b is offline
post #17 of 20 Old 07-09-2014, 09:06 AM
nyctveng's Avatar
Quoted: 114 Post(s)
Liked: 65
I have dangled a $2 Radio Shack bow tie out of 2nd floor Manhattan apts and picked up stations 50 miles away. Might be worth a try as long as the antenna is not visible from street level, building management won't complain.
nyctveng is offline
post #18 of 20 Old 08-22-2014, 11:48 PM
Maeve011's Avatar
It would make a great stripper pole ,,, or, if yr more adventurous, use it as a sex toy on her, heheh. I would if I had one, cuz I'm a lil weird!!
I tend to agree w/ you there, as I have been known to knock on people's doors to compliment, and then ask them, about their rooftop antennas. A lot of guys actually give me their phone number, oddly enough. Even when my son is with me, they seem to think I'm hitting on them, lolz! I just love antennas THAT much....
Maeve011 is offline
post #19 of 20 Old 08-24-2014, 01:46 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
It is ulgly, an eyesore, and potentially dangerous in the middle of the night!
With that being said, I myself have a CM4228 antennt up on about an 8 ft pole near the top of the vaulted cieling in my apartment and have terrific reception to all channels, while a regula bowtie antenna performed poorly back when I was doing my experiments as. I finally bit the bullet and bought the 4228 and have not regretted it and almost forget that it is even there anymore....
Could you find a big enough lamp shade and disguise it as a lamp? Sorry.....
Good luck.
qz3fwd is offline
post #20 of 20 Old 08-24-2014, 07:59 PM
rezzy's Avatar
Quoted: 993 Post(s)
Liked: 752
Maybe you can attempt to hide it a little:
http://www.aliexpress.com/promotion/...promotion.html
I cannot guarantee there won't be any multipathing, LOL!
"I knew you'd say that"...*BLAM!*
rezzy is offline
Reply HDTV Technical
