What is Difference between ANT751; ANT751R, ANT751 DGTL - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-09-2014, 09:35 AM - Thread Starter
Samson3113's Avatar
Hi Folks
anyone know what the difference is between these three models
Jim
Samson3113 is offline
post #2 of 7 Old 05-09-2014, 09:50 AM
Calaveras's Avatar
Quoted: 1082 Post(s)
Liked: 253
Seems to be different names for the same thing. I even found it called ANT751R DGTL.
Calaveras is offline
post #3 of 7 Old 05-09-2014, 10:03 AM - Thread Starter
Samson3113's Avatar
My bad. I left off the R
post #4 of 7 Old 08-28-2014, 08:18 AM
Quoted: 146 Post(s)
Liked: 57
The 751R is the newer version of the 751. Before the OTA digital conversion in '09, UHF channels went up to channel 69. After the conversion, UHF channels only go to 51. The 751R was re tuned to receive a higher gain on the lower UHF channels. Otherwise, the two models are identical.
Futrader8 is offline
post #5 of 7 Old 08-28-2014, 11:56 AM
tylerSC's Avatar
Quoted: 708 Post(s)
Liked: 166
The 751 is made by Winegard but sold by Audiovox under the RCA brand.
tylerSC is offline
post #6 of 7 Old 08-30-2014, 06:33 AM
Liked: 0
Hi,
I am new to AVS forums. I am using digital antenna's from 2007 and am able to get good # of channels in NJ. Originally i had a $18 antenna and was getting channels from Philly. Then i upgraded to $35 antenna from ebay and it dropped a few channels.
This week i upgraded to RCA ANT751 and i am not getting any channels. even though it is highly rated.
For all regular channels
I have signal strength in high 80's
SNR in high 20's
IF-AGC(%) above 100.
Should i get an amplifier? or change the cabling?
Please help.
Venkatasiva08 is offline
post #7 of 7 Old 09-04-2014, 09:58 AM
ADTech's Avatar
Quoted: 118 Post(s)
Liked: 63
SNR in high 20's
That means the antenna is working but your TV isn't, the tuner probably is confused.
Flush the tuner (reset it by running a scan with no antenna connected) and re-run the channel scan. That often fixes it.
Tech support for Antennas Direct
ADTech is offline
Reply HDTV Technical
