http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de1c668f7b343c3
I currently have 4 tv's in my home. I plan on ditching cable within the next couple of weeks. I was hoping to install an antenna in my attic to serve the rest of the house. I am mainly concerned with the major network channels. I have cable ran to two of my televisions already, the others have indoor antenna's, and could possible continue to use them. It should be fairly easy for me to drop a cable down from the attic to where my cable is split. Would it be possible for me to use the same cable that currently goes to my cable boxes, and hook it up to my tv and dtv converter??
Bottom line is that I need some suggestions on what type of antenna to buy.
Thanks for all your help, I am sure you get tired of answering these questions.
-Shawn
-Shawn
